Re: Emerson vs Hitachi vs Huanyang. What is your experience with your VFD?
Originally Posted by
Dan2464
Looking for input on what you guys are running.
I brought a Huanyang in a while ago for evaluation and experimentation, particularly for use of the RS485 input, as I found out from the Mach forum, it is NOT truly Modbus compatible.
The 70 page manual I received has a passing mention of having RS485 and very little else, there is no way without many hours of experimentation to find out the command protocol, fortunately I communicated with someone on the Mach forum who had reverse-engineered it also wrote a plug-in for it..
Over the years I have used the likes of Allen-Bradly, Mitsubishi, Telemecanique VFD's, and of course there is no comparison as to the quality of documentation and particularly important, Support.
I think you will find that most that have used these have relied on those that have gone before and deciphered much of the method of operation and pitfalls.
Basically a case of 'You get what you pay for'
Al.
