587,012 active members*
3,408 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Laser engraving on anodised aluminum - chinese 40w CO2 laser
    Jan 2014
    4
    Question Laser engraving on anodised aluminum - chinese 40w CO2 laser
    Hello everybody,
    today I borrowed my friend's laser machine-time to do some testing.
    It's a cheap 500$ chinese 40w CO2 laser.
    He uses it to cut plastics and wood, and to do some engraving on wood.
    We tried etching the anodisation layer on an aluminum cover, but the results are quite disappointing.
    We started with 30% power, 1000dpi, 250mm/s
    The file is a one bit bitmap, where black is "engrave", white is "don't engrave".
    Software is CorelDRAW Laser.
    The thing works fine on paper, with horizontal scanning of the graphics; however, on the aluminum there are some strange borders around the graphics, that of course are not in the file.
    The etched part should be solid.
    We tried fiddling with power and speed, but other than a general dimming/brightness of the entire graphics, there is no difference and the border is always there.
    You can see from yourselves in the attached picture.
    Did you ever experienced something like this? What's your suggestion?
    Thank you very much in advance
    Dec 2005
    160
    Re: Laser engraving on anodised aluminum - chinese 40w CO2 laser
    may be too much power. Check out Russ Sadler
    https://www.youtube.com/watch?v=PbHVI3aNIuw
    Jul 2017
    19
    1. co2 laser not suitable for aluminum.
    2. the main reason of line is material problem. If it is bitmap, its resolution ratio also influence it
  1. Chinese Laser not Engraving
    By Winner7 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-06-2016, 01:48 AM
  2. Laser Machine for Engraving Anodised Aluminium?
    By darpitus in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-29-2015, 09:08 AM
  3. Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
    By Andriette in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2014, 03:44 PM
  4. Cannot laser etch anodised aluminium
    By jimmykeeley in forum Commercial Laser
    Last Post: 12-01-2013, 08:08 PM
  5. Engraving small letters on Anodised Aluminum
    By engravernorfolk in forum Engraving Machines
    Last Post: 05-23-2012, 03:42 PM
