586,845 active members*
2,406 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Cutting numbers in a circle? Advice needed! Use F-Engrave? If so what settings?
Results 1 to 8 of 8
    Dec 2015
    12
    First let me say I am a total newb with CAD/CAM. I have mainly been using my cheap Chinese engraver for drilling printed circuit boards. The software pretty much shields you from the G-Code.
    What I want to do is to build a hard drive POV clock like this.
    The numbers on that disk are translucent and LEDs are illuminated behind them . at the appropriate time. What this guy did is to cut those numbers out by hand. My skills with a handsaw aren't all that great and I have this engraver so why not use it?
    I need advice on how to cut these numbers. One thought I had was to paint a piece of plexiglass black then etch though the paint with the engraver. First I need to know if that will work.
    If so my next need is to know exactly how to do this. I was going to use F-Engrave but don't know where to go from there. Should I use V-carve or Engrave? What bit should I use?
    Playing with f-engrave in the past, I swear I was able to outline the characters but I can't seem to get that to work. Perhaps I am thinking of the Linux CNC example? Anyway if I could outline the characters, one thought there would be to route the outlines then scrape off the paint by hand.
    That way I can use the bits I have on hand. I don't have much in the way of bits right now but open to buying more. I have a .25 inch flat bit and some of those small engrraving bits. The ones I am looking at now are 0.8 mm 30 degree. The 0.8mm is the width of the tip of th ebit.
    Any suggestions?
    Apr 2009
    5516
    Re: Cutting numbers in a circle? Advice needed! Use F-Engrave? If so what settings
    Very easy with V-Varve to put text onto an arc or circle...
    Dec 2015
    12
    Do you mean V-Carve? Yes I know. I have already done it. What I need to know is what type of bit I might use to do what I want to do above..
    I would also like to know the difference between V-Carve and Engrave.
    Apr 2009
    5516
    Quote Originally Posted by spinnaker15136 View Post
    Small endmill maybe .020-025"? Using offset toolpath... .005" DoC...
    Dec 2015
    12
    Thanks. Can you help me on the offset toolpath part? How would I set that? What is DoC? Sorry I am a total newb on this stuff.
    Apr 2009
    5516
    There's an icon symbolizing pocket cutting. You can choose raster or offset. Choose offset. DoC is depth of cut. Set the stepover to about 15-20% as these are small tools. I'd try 10ipm to start. Buy extra tools because they're cheap enough, and you'll break one. Or three...
    Dec 2015
    12
    Quote Originally Posted by louieatienza View Post
    An icon in F-Engrave?? If not what application are you referring?
    Dec 2015
    12
    I do see an X an Y offset setting in General Settings.
  1. Need advice on the calculations for cutting a semi-circle on the XZ axis
    By tooold in forum Mechanical Calculations/Engineering Design
    Last Post: 11-28-2017, 01:36 AM
  2. Replies: 2
    Last Post: 07-29-2013, 12:14 AM
  3. macro to engrave serial numbers
    By nmn in forum Parametric Programing
    Last Post: 05-29-2009, 03:33 AM
  4. Cutting advice needed
    By ninauk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-27-2006, 12:33 AM
  5. How do I engrave numbers...
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 10-15-2004, 08:35 PM
