586,525 active members*
3,186 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > Harmonic grease 4B-No.2 alternatives?
Results 1 to 11 of 11
    May 2010
    24
    A while back I got myself a harmonic drive off ebay ..actually a new one for dirt cheap. It was from a new other DENSO robot so I asked them what grease they used for it and apparently this stuff must be made of gold as they wanted 500 bucks for .5kg of which I would need about 20grams
    Anyway if anyone has any idea of where to get some smaller amount or an alternative suitable grease I would love to know about it.
    the one they recommended was called
    Attachment 382380
    Apr 2004
    5741
    Re: Harmonic grease 4B-No.2 alternatives?
    The problem is that harmonic drives have rubber gears, so there's a danger of damaging them if you use regular grease, which often is corrosive to various types of rubber. If your device doesn't absolutely need new grease, I'd say leave it alone.
    Andrew Werby
    Website
    May 2010
    24
    Thanks Andrew, sadly it needs grease. Where are the rubber parts?
    Apr 2015
    170
    As a last resort you could use either silicon grease or rubber grease like the grease that is used for car brake cylinders. Both are inert as far as rubber components go though it may be too thick. Dave
    May 2010
    24
    I wouldn't mind forking out some money for it but just not what I was quoted. I did find a supplier for the one of the other types but its not what I was recommended.
    https://www.rmhoffman.com/store/p76/...onic_SK-2.html
    Still im not sure I see any rubber parts in this drive..the flex spline and the teeth are metal or am I missing something here
    Jun 2010
    4256
    Hi Andrew
    They do?
    Not as far as I know! Hardened SS, yes, but the only rubber in an HD is in the seals.
    Frankly, I see little reason why one could not use ordinary EP grease.
    Cheers
    Roger
    Apr 2004
    5741
    Roger's right; the gears in those reducers aren't made of rubber but they do have rubber O-rings. I'd still suggest using the lubricants they specify, on page 16 of this catalog: http://www.harmonicdrive.net/_hd/con...er_catalog.pdf , depending on the conditions it will be run in. If you can't find it or it's outrageously expensive, you might try asking them if EP grease or whatever you can find will work.
    Andrew Werby
    Website
    Jun 2010
    4256
    After all, Viton and Neoprene (and most if not all other common O-ring formulations) are compatible with just about any grease you can think of.
    If you are going to be running your HD under extreme conditions - near max speed or loading, or in a vacuum, (or the lot!), then some care must be taken. But if you are using your HD to make a small rotary table or similar, then conditions are quite benign.
    Cheers
    Roger
    May 2010
    24
    Roger you kinda guessed it.. this is for a 4th axis for my cnc machine No rubber seals on this one yet as its just the 3 component gear set without bearings in which I will makeup a spindle for using some nachi angle roller bearings. Should give me a great resolution and quite high torque along with a decent servo. build pictures in another thread once its come along a bit.
    Jun 2010
    4256
    Hi Nava
    See http://www.cnczone.com/forums/linear...gineering.html for some ideas.
    Cheers
    Roger
    Dec 2023
    Look for greases with NLGI grades 2 or 3, extreme pressure (EP) and high temperature resistance. Some popular brands include Mobil SHC 1000, Castrol Tribol GR 222, and FAG Multilube EP 2.
  1. SBR16 bearing truck grease/grease fitting?
    By isaac338 in forum Linear and Rotary Motion
    Last Post: 03-11-2014, 08:08 PM
  2. New to CNC, what parts to grease and with what type of grease? Wood machine.
    By 777funk in forum DIY CNC Router Table Machines
    Last Post: 11-22-2011, 04:45 PM
  3. Is this a harmonic drive?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 02-14-2011, 08:06 PM
  4. need help harmonic drver
    By turbopop2001 in forum CNC Machine Related Electronics
    Last Post: 02-06-2006, 02:30 AM
  5. Harmonic Drive
    By juzwuz in forum Mechanical Calculations/Engineering Design
    Last Post: 12-03-2005, 08:28 AM
