587,058 active members*
3,898 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > How to use merge command
    Aug 2005
    177
    I have a complex 3D carved model, well, complex for me anyway. Customer made a small change to planar surface.
    What is the best procedure to swap the new model in.
    Do I open my file, that is already coded, delete the model and use merge with new model. Then reselect all geometry and compute all?
    Mar 2012
    1570
    Re: How to use merge command
    yes
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Aug 2005
    177
    Thank you. I must be getting a handle on this
    Rob
    Dec 2011
    295
    What is the difference between copy/paste, boolean add and merge? I ran into probs a couple days ago.
    Dec 2008
    4548
    Quote Originally Posted by LeWhite View Post
    Copy and paste is creating duplicates of objects...
    Boolean operations are basically several lower level commands bundled into a single command, as they were often used.
    Such as, calculating intersection values, trimming and discarding the desired unwanted pieces and stiching the pieces back to a solid again. Booleans are usually meant for solid ooerations.
    A boolean "merge" commamd should give you a result of ALL the boolean calculations. Boolean add, subtract and isect (intersection), but left as all seperate solid pieces, with no discarding...
  1. Merge NC Programs in one NC File
    By zreqi in forum PowerMILL
    Last Post: 03-11-2017, 12:46 PM
  2. Move command works until velocity command issued
    By madprinter in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-30-2015, 01:06 AM
  3. Surface merge in ProE
    By pejasinovic in forum PTC Pro/Manufacture
    Last Post: 02-12-2014, 10:45 AM
  4. How to Merge programs in memory
    By chipsahoy in forum Fanuc
    Last Post: 01-11-2010, 05:53 PM
  5. Bob-cad Tool Merge Problem
    By j-radkemachine in forum BobCad-Cam
    Last Post: 02-09-2007, 03:41 PM
