586,430 active members*
4,043 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Cent.4 wont read I or J help
    Jan 2007
    15
    Anyone have any ideas, my centurion 4 control will not read I's or J's when program is posted via the DNC. Reads I's and J's fine if programmed on machine control.
    Any help would be greatly appreciated.
    Jeff
    Mar 2005
    171
    What software are you using? and what are your comm settings?
    Are you drip feeding or just sending the program into the Centurion's
    memory? Can you download from the Centurion's memory into the PC
    correctly?
    Jan 2007
    15
    I'm using Mastercam version 7, program looks good. I'm sending the data via the DNC. I have not tried to download memory from machine to the PC.
    Feb 2007
    156
    Jeff,
    There is something missing in your file. What I would do is write a small program that works at the mill, then write the same program in mastercam and compare them. Seems to me I had a problem similar to what your having and it was just something stupid with the post, could be it's omitting the circular command (G02/G03) in one or more lines. or it's calling the wrong work plane or it's not calling the plane at all.
    Dave
    Schneider Machine
    A force of one
    Mar 2005
    171
    Jeff,
    I agree with Dave1, write a small program like he says an try it out. One thing
    I have noticed on Centurion IV's is it doesn't take much to foul up their programming. For example, a feedrate command at the end of a line instead
    of the beginning can screw up a linear or arc move. If you are using line numbers? that can be an issue if they are used incorrectly. If you are programming in the XY plane, G17 is always part of my first line of programming, even though this is the default plane.
    I would above everything else, make sure my communications were uploading
    and downloading programs correctly into machine and pc memory before ever
    attempting DNC.
    goodluck
    Ben
  1. Replies: 8
    Last Post: 11-15-2007, 06:16 PM
  2. cent 6 I/O
    By HANSENTECH in forum Milltronics
    Last Post: 12-03-2006, 11:27 PM
  3. Cent 7 Program an elipse??
    By out**cold in forum Milltronics
    Last Post: 10-25-2006, 02:33 PM
  4. Seventeen cent grab bag
    By MrWild in forum Stepper Motors / Drives
    Last Post: 03-22-2006, 05:34 AM
  5. Need help installing windows 95 - cdrom wont read
    By Hack in forum Computers / Desktops / Networking
    Last Post: 02-15-2005, 05:03 AM
