586,785 active members*
3,144 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > New here and i have a qustion about this sherline
Results 1 to 3 of 3
    Jun 2014
    2
    Question New here and i have a qustion about this sherline
    Hello,
    New here I have really enjoyed reading the posts on this form.
    I have a question,
    Recently bought a sherline lathe and mill and would like to know if anyone here knows anything
    About the control box?
    And are these steppers or servos?
    and is this set up ready to run?
    Attached are pictures
    Thanks all
    Daniel Escobedo
    Attached Thumbnails Attached Thumbnails 20171210_115212.jpg   20171210_115217.jpg   20171210_115221.jpg   20171210_115229.jpg
    Feb 2007
    711
    Re: New here and i have a qustion about this sherline
    Those are stepper motors. You might want to open up the box to see what each of the db25 connectors go to. If you can find documentation somewhere, you should be able to configure it to run on a pc control.
    Apr 2004
    5742
    You still need a computer in the system. Sherline uses a linux-based control software which is free to download from linuxcnc.org. You should be able to get the required setup files from Sherline. Here's a document that explains how the software works: MINI GUI
    Of course, if you've only got one control box for both machines, you'll need to switch it over every time you want to switch from the lathe to the mill and back. Be sure to turn everything off and let the capacitors drain before disconnecting and reconnecting the motors.
    Andrew Werby
    Website
  1. qustion
    By haroutkhaloian in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-12-2014, 02:11 AM
  2. New ATC for Sherline
    By kdoney in forum News Announcements
    Last Post: 05-05-2010, 06:45 PM
  3. qustion about ISL1208
    By Jo_Jo in forum CNC Machine Related Electronics
    Last Post: 04-04-2006, 10:26 AM
  4. Qustion about buying a VH65 4th axis
    By Grip in forum Fadal
    Last Post: 12-02-2005, 12:35 AM
  5. Home made taps qustion
    By ezland00 in forum Toolgrinding / Toolgrinding Machines
    Last Post: 01-27-2004, 01:58 AM
