586,551 active members*
3,317 visitors online*
    Oct 2005
    20
    Boss Laser 65w Tube 5,000 hours
    Boss laser lists a 65w CO2 Tube for $597.
    https://www.bosslaser.com/60w-co2-laser-tubes.html
    States up to 5,000 hour life. Its a 1200mm tube. First, I thought 1200mm was 60w. Second, that seems like an really long time for a CO2 tube. I need a new tube so I'm intrigued. Is this realistic? Does anyone have any experience with this tube?
    Chris
    Jan 2008
    940
    Re: Boss Laser 65w Tube 5,000 hours
    Do they mean 5000 hours from the date that is on the tube or for the time the tube runs. Remember that they do say up to but that could be just a few seconds of use.
    Nov 2012
    492
    if the tube is 1200 mm its a 60 watt tube not 65, it will probably put out 65 watt at the beginning but will drop pretty quick to 60 watts. As for 5000 hours it says up to 5000 which means to me anything from 5 min's to 5000 hours with maybe getting 1000 to 2000 a good bet
  1. Laser troubles... 130W tube possibly dead with just a few hours
    By DRobs86 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-15-2017, 02:34 PM
  2. Nozzle\Mixing tube just expires in 20 hours
    By qasimk in forum Waterjet General Topics
    Last Post: 04-17-2015, 03:38 AM
  3. Boss 5 or 6 machine runs for only 3-4 hours a day
    By tapburrbit in forum Bridgeport / Hardinge Mills
    Last Post: 10-30-2011, 04:34 PM
  4. New Chinese 8000-10000 hours lifespan Tube
    By oneeye in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 04-22-2010, 09:50 AM
  5. Bridgeport Boss 9 Low Hours No controller
    By electromech31 in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2010, 07:42 AM
