586,594 active members*
2,971 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > G93 inverse mode freezing machine
    Sep 2006
    296
    I am trying to run a '98 model VF with an HRT-210 4th axis in G93 mode. Runs fine for a bit but will freeze after maybe 5 seconds of running. No alarm, the control just hangs. It will reset and start over just fine. I suspect the feedrate has something to do with it. I have the max feed set at 15,000 in my post processor. Anything much over 15,000 gives an alarm "331 RANGE ERROR" when it finds a line with higher feedrate than that. Runs fine in G94 mode but i really would like to get the G93 mode working. My program makes a lot of tiny moves less than .0010" in distance but it doesnt seem to be running through the code to fast.
    Anybody got much experience in this area?
    Nov 2006
    490
    Re: G93 inverse mode freezing machine
    I have the same issue with a mill of similar age. We limit the G93 F-values to a much lower number. I do that partially due to the control but also because the old hardware can't really handle it anyway...
    Sep 2006
    296
    What is the max feedrate you use with G93 if you happen to know off hand?
    Nov 2006
    490
    I have it set to F2000.0 although of course it also depends on the geometry. The mill doesn't have the HSM option so I've found the actual speed is pretty non-noticeable when programmed quicker. It's drastically different with newer hardware, that's for sure...most of the parts we run on this machine are done as 3+2 since the equipment has less capabilities, but you do what you gotta do.
    Sep 2006
    296
    I limited the max feed to 5,000. in the post processor and it ran the code fine. Did have to open up the in position limit for the 4th axis to prevent it from stuttering during small moves but it works. Thanks.
  1. Okuma Milling Machine freezing
    By Maint-guy in forum Okuma
    Last Post: 12-09-2015, 06:59 PM
  2. Machine Freezing up after finishing a cut..
    By ffokazak in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-04-2013, 06:51 AM
  3. Machine freezing
    By tturnbull50 in forum G-Code Programing
    Last Post: 06-02-2008, 12:24 AM
  4. DX-32 freezing in edit mode?!?!?
    By mlbz420 in forum Bridgeport / Hardinge Mills
    Last Post: 05-16-2007, 12:37 AM
  5. G93 Inverse Time Feed Mode
    By MarkT in forum Haas Mills
    Last Post: 01-18-2007, 07:28 PM
