586,535 active members*
3,036 visitors online*
    Apr 2011
    720
    4th axis gear ratio ?
    Hi All,
    Does anyone know if you can set or change the 4th axis gear ratio in pathpilot, or maybe it can be handled in CAM?
    I have a Tormach 8" fourth, which has a 90:1 ratio, but I'm in the process of modding a small 3" table with an arduino/stepper setup. It has a 36:1 ratio, but I'm thinking if I build it with a cable connector that match's the 1100, I could use it on the mill also. Since it only weighs about 10 lbs, sometimes that would be preferable to the big table.
    Terry
    Dec 2008
    740
    Re: 4th axis gear ratio ?
    Quote Originally Posted by MFchief View Post
    Hi All,
    Terry
    Hi Terry,
    I PM'd you.
    Regards
    Step
    May 2017
    25
    Quote Originally Posted by TurboStep View Post
    Hi Terry,
    I PM'd you.
    Regards
    Step
    I know this is likely a dead thread... but how is the scale determined? It doesn't make any sense to me.the step count for the harmonic drive isn't 141.6666666 steps per revolution.
    My 4th axis is a 6:1 reduction from amazon. I have it wired up and I can get it to jog, but the scale isn't right.
    Apr 2011
    720
    This is the advice I was given back in 2017.
    "At the end of your .ini file in configs/tormach_mill you'll find the [AXIS_3] section. The number of pulses per degree is set by the SCALE parameter:
    SCALE = 500.0
    You'll need to change this by the factor 36/90 which gives you a new value of 200."
    I hope it helps.
    Terry
  1. system parameter of B axis gear ratio
    By y2121411 in forum OKK
    Last Post: 02-08-2017, 04:40 AM
  2. I need help with gear ratio.
    By modelaratrod in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-14-2016, 03:20 PM
  3. How to get a 705:1 gear ratio
    By intel2you in forum Mechanical Calculations/Engineering Design
    Last Post: 04-12-2012, 03:22 AM
  4. which gear ratio
    By sempar in forum Linear and Rotary Motion
    Last Post: 07-24-2007, 09:55 PM
  5. gear ratio help
    By Erick Davidson in forum Waterjet General Topics
    Last Post: 05-30-2006, 04:04 PM
