586,655 active members*
4,147 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > Path Pilot 2.0 Get Ready!!! Tormach has a page for it now!
Page 4 of 4 234
Results 61 to 70 of 70
  1. #61
    Jul 2004
    1424
    Re: Path Pilot 2.0 Get Ready!!! Tormach has a page for it now!
    I was wondering the same thing. It isn't movement volume:
    1100: 2779 ci
    770: 1391 ci
    440: 625 ci
    It isn't table area:
    1100: 323 in^2
    770: 208 in^2
    440: 113 in^2
    The closest thing seems to be motor Watts:
    1100: 1.5 hp = 1119 W
    770: 1.0 hp = 746 W
    440: 2/3 hp = 497 W
    Or maybe weight (without stand)
    1100: 1130#
    770: 662#
    440: 450#
    Tim
  2. #62
    Jun 2004
    6618
    I have always assumed it was weight. It seemed to be pretty close. Slant Pro 15 is not as cryptic.
    Lee
  3. #63
    Jul 2004
    1424
    Quote Originally Posted by LeeWay View Post
    It does seem kind of weird. Many manufacturers name their mills by tables size, and their lathes by swing (diameter). Weight doesn't really adequately describe the machine's capabilities.
    In that case, we should have the PCNC3410, PCNC2608, and PCNC1806.
    Tim
  4. #64
    Nov 2016
    109
    Quote Originally Posted by tmarks11 View Post
    There are rumors of a larger Tormach mill with linear bearings on the ways. Maybe this is it. Although I would think that would be named a PCNC2200 or something like that. PCNC50 doesn't seem to follow their current naming convention.
    Sure hope we aren't gettin' excited over a 50lb machine lol. Maybe it would come with backpack straps.
  5. #65
    Jul 2004
    1424
    Quote Originally Posted by petenc View Post
    50#? That would be in 3D Printer territory... which seems unlikely, as that market is already swamped.
    Tim
  6. #66
    Jan 2009
    234
    the 50?? 8" X 4.8" X 5.125" ??? small machine.
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
  7. #67
    Feb 2007
    1538
    You might be overthinking it, it may be more marketing based.
    Why not start with the 1100...it was the first model That was based on weight. It was 1100 lbs. So it began....
    Then the 770 was just a proportional guestimate for a smaller version with a number that sounds good for marketing.
    And the 440 the same.
  8. #68
    Jan 2009
    234
    Just Dawned on me the A50 is the band Saw maybe the 50 is the bandsaw?
  9. #69
    Apr 2013
    1788
    Quote Originally Posted by TurboStep View Post
    Which manual did you download? I tried all the latest manuals I could find online but no of them described the profile feature.
    I've nevertheless been playing with it for a while and I was quite impressed with the first tests in imperial units (I haven't run the profile routine on the machine yet - maybe tomorrow). However, it took me a few attempts to get it running in metric because it carried some initial values from imperial and it wasn't too happy. Once you get the hang of it it's actually quite nice Just check over ALL the values.
    Step
    There is now a Tormach video on using the profile feature:
    https://www.youtube.com/watch?v=NcibPZH-6xY
  10. #70
    Jul 2004
    1424
    Quote Originally Posted by Contract_Pilot View Post
    Could be. Seems like an unfortunate choice to have a PC run that thing. All you are selecting is cut width X ## of pieces. Seems like you could run that thing with an arduino. They managed to run the steppers for their surface grinder without resorting to PC control.
    Tim
Page 4 of 4 234
  1. Buying Path Pilot from Tormach
    By thumper650 in forum Tormach PathPilot™
    Last Post: 10-28-2017, 02:08 PM
  2. Install path pilot on a non tormach mill
    By Csmetal in forum Tormach Personal CNC Mill
    Last Post: 05-29-2016, 06:33 PM
  3. Mastercam X8 and Tormach Path Pilot
    By jt8501 in forum Tormach Personal CNC Mill
    Last Post: 02-26-2016, 06:27 PM
  4. What comes with Tormach's path pilot?
    By 1abrat in forum Tormach PathPilot™
    Last Post: 11-26-2015, 08:23 PM
