586,570 active members*
3,596 visitors online*
Results 1 to 18 of 18
    Mar 2017
    11
    Angry Gerber Sabre 408
    My old 408 will not start.
    When I want to do the warm upp I get:
    !!!!!!!!!!!!!ERROR!!!!!!!!!!!
    SPINDLE I/0 FAILURE
    ATC works
    X,Y, Works
    Help e plz
    Nicklas
    Nov 2017
    9
    Re: Gerber Sabre 408
    I have the same problem with 404.
    Are you using the three-phase spindle?
    Mar 2017
    11
    Quote Originally Posted by danilnetu View Post
    Three-phase Colombo 10 HP with ATC
    Mar 2017
    11
    Recieved this email from Gerber Service:
    Open you spindle controller and turn everything on, it should say calling or call waiting on the display, do a motor warm up does the display change?
    It should change to 100hz if you do a motor warm up from the keyboard.
    Let me know if you get an error code.
    But if it does not change at then yes you most likely are having an issue with the DUART card or cable that runs between the electrical box and the spindle controller box.
    Nov 2017
    9
    Quote Originally Posted by STYF View Post
    I've done that.
    The cable is fine. The spindle controller only shows "call".
    Ordered a new duart card. Will try that on Monday.
    What kind of spindle controller do you have?
    Mar 2017
    11
    I've done that.
    I can’t remember the name of the inverter.. I can run the spindle manually from the inverter.
    Did you order a duart card from Gerber?
    How much do they ask?
    Nov 2017
    9
    Yes, I ordered it from Gerber. $983.42
    Do you know if I can get it from a different place?
    I can run it manually from the inverter but I do not like that.
    I hope the inverter should be reprogrammed.
    Do you know if I can use another type of controller for the spindle?
    I can see they sell em on amazon for $300-$400
    Mar 2017
    11
    Hi!
    I replaced the two Max251 CPD components on the DUART-card
    Yesterday (about 20$) and now it works great again!!
    Nov 2017
    9
    That's great.
    The new DUART card has just arrived and it still doesn't work.
    I'm afraid I will have to ship the inverter to get reprogrammed.
    Jan 2017
    41
    buy a new inverter. I have a 408 with the 7hp three phase spindle, this is the inverter i used, it is 220V single phase > 220V three phase. I do not know if it will suit yours, but i do think it will be cheaper buying a new inverter than sending the old back.
    https://www.ebay.co.uk/itm/171670470975
    Jan 2017
    41
    This is my old inverter, it still works but i cant use it because i dont have three phase at my house. Is it the same as yours?
    Nov 2017
    9
    Hello.
    Thank you for your help.
    That's the one I have.
    How did you connect the new inverter? Is there a serial port in it or you hardwired it?
    I'm pretty sure we have the same 7hp spindle, black and heavy.
    Jan 2017
    41
    i didnt wire it yet im still collecting the parts for the project. My Gerber was not working when i bought it so I have never worked with the original control panel.
    I can sell you the original inverter for 100 if you like. . Are you sure its the inverter that is the problem?
    This is my spindle, perske, black and heavy, no ATC
    Mar 2017
    11
    That's great.
    I’m sorry to hear that.
    Do you have the inverter manual?
    Nov 2017
    9
    Yes, I do.
    I will check the parameters today.
    The Gerber tech support emailed me the list of parameters for the sabre.
    Nov 2017
    9
    Updated the parameters.
    No luck.
    Checked the wire that goes from the CNC control box to the inverter with a meter, it reads 9 volts.
    If I start the CNC machine without DUART card it doesn't show the error that the card is missing, but I think it should.
    Mar 2017
    11
    No luck.
    Hi!
    I can check the voltage on Monday.
    My 408 didn’t give any error code if I disconnected the DUART-card either.
    Mar 2017
    11
    Hi Ned
    Do you still have the P5 inverter lying around?
    If Yes I am interested.
    Best regards Nicklas Styf
  1. Gerber Sabre 408 help...
    By crackstar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-19-2018, 01:29 PM
  2. Gerber Sabre 408
    By bulld101 in forum Gerber
    Last Post: 05-04-2016, 10:20 PM
  3. gerber sabre 408
    By nipon in forum Community Club House
    Last Post: 11-10-2013, 07:03 AM
  4. Evaluating a Gerber Sabre
    By ToolslingerNJ in forum Want To Buy...Need help!
    Last Post: 05-22-2011, 02:51 AM
  5. Gerber Sabre 408
    By Pasty in forum Want To Buy...Need help!
    Last Post: 07-21-2008, 03:52 PM
