586,974 active members*
3,463 visitors online*
Hybrid View
    Nov 2017
    Powermax 30XP + Plasmacam
    Is the Powermax 30xp ok to run on the Plasmacam?
    If so, do I need a dedicated compressor for this system or can I use my regular Woodshop airlines/compressor?
    Thanks!
    Jan 2008
    2247
    Re: Powermax 30XP + Plasmacam
    Hypertherm generally recommends its plasma cutters that are available with machine torches and with output amperage of 45 amps or higher for CNC cutting machine use. There are a number of people using the Powermax30XP on Plasmacam tables.....and it certainly will work. Because this system was designed for portable hand cutting operation it's duty cycle and thickness capacity should be downgraded when used on a cnc machine like the Plasmacam. I would recommend a maximum piercing thickness of 3/16" for machine use, and supply 230 volt power to the 30XP for best results.
    The 30 XP uses approximately 4.5 cubic feet per minute at 90 psi. If your compressor can supply this amount of flow it will be adequate.Inlet pressure when air is flowing at the torch must be between 90 and 120 psi. Jim Colt Hypertherm
  1. What Do I Need? Plasmacam 4x4 Powermax 45
    By rderkis in forum PlasmaCam
    Last Post: 12-03-2012, 07:49 PM
  2. Powermax 45 for use on PlasmaCam Questions
    By mjbdesigns in forum Hypertherm Plasma
    Last Post: 09-01-2012, 08:13 PM
  3. What can a PLASMACAM do that . . .
    By CNCCajun in forum PlasmaCam
    Last Post: 04-07-2009, 09:31 PM
  4. plasmacam
    By oiw in forum PlasmaCam
    Last Post: 03-02-2009, 02:18 AM
