586,801 active members*
6,424 visitors online*
Results 1 to 8 of 8
    Sep 2006
    27
    Drilling a .010 hole
    I need to drill a .010 hole about .060 deep...I need a short drill so there more rigidity. I am making sight pins for archery sights.
    Mar 2006
    2712
    I don't know how many you need, but you might be better off having them "drilled" on an EDM machine.
    DZASTR
    Jan 2007
    634
    This may not work for your application, but if I need a whole bunch of holes in a line the way I think you do for the sight pins, I am lazy and usually cheat by milling or engraving half-round grooves in two separate pieces and bolting them together.
    Last used that on a fuel atomiser, as I didn't fancy drilling dozens of .012 holes .500 deep!
    Sep 2006
    27
    This is what I am making
    224
    One picture is worth a thousand words!
    So is the 0.010" hole you need the main hole that the lens fits in? or ??
    Sep 2006
    27
    I am making the pin, here is a pic of just the pin
    Sep 2006
    27
    Click on the image so you can see it.
    4826
    I bought a few .010" drills lately from Travers Tool. They had a pretty good selection, the shank is 1mm, I believe, and the flute length is reasonably short and stiff. I managed to drill without a starter spot....didn't think I had anything that would make a good starter dimple for it anyways.
    Oh, I used a spindle speeder to run it at 15,000 rpm. I went real real slow on the feed.....about .5 ipm in 303 stainless......I did not want to spoil the job. I managed to drill about 30 holes per drill, only penetrating about .015 material thickness.
  1. Postprocessor code always drilling same hole twice
    By Maurice Proulx in forum SprutCAM
    Last Post: 12-08-2006, 04:03 AM
  2. Homebuilt CNC Hole Drilling Machine
    By nitrosaturn in forum DIY CNC Router Table Machines
    Last Post: 11-14-2006, 09:44 AM
  3. Drilling a hole in a 3D model
    By mayhugh1 in forum SprutCAM
    Last Post: 10-25-2006, 05:51 PM
  4. Accurate Hole Layout & Drilling
    By vacpress in forum Mechanical Calculations/Engineering Design
    Last Post: 04-19-2006, 06:21 PM
  5. Deep hole drilling on OKK
    By eddie in forum G-Code Programing
    Last Post: 09-22-2005, 12:55 AM
