587,033 active members*
3,484 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Work Fixtures / Hold-Down Solutions > What does everyone use to hold down thin balsa and plywood on their CNC Router spoilb
    Oct 2017
    I’m in the process of designing/building my 2nd CNC machine, first one was a 3D printer. I’m clueless about holding thin materials, as all I’ve seen are clamping systems for thicker materials.
    Mar 2012
    378
    Re: What does everyone use to hold down thin balsa and plywood on their CNC Router sp
    I use double sided tape a lot.
    Apr 2004
    5742
    Vacuum is the most common, and it works well for thin stock. The other way is to use a double-stick tape of some sort. Are your pieces all the same size, or do you need to accommodate all sorts of different shapes? Vacuum works best the tighter the fit between the pod and the material being cut, but it's possible to lay something around the edges to block the flow of air if necessary to retain vacuum pressure. Although small pieces can be held down by a shop vac, anything sizable requires a high-volume low pressure vacuum pump.
    Andrew Werby
    Website
    vacuum with a MDF undercarrier plate for the product to lay on
  1. Best Cutter for thin plywood
    By JCraft in forum Chinese Machines
    Last Post: 03-09-2015, 12:34 PM
  2. Best way to hold thin material for milling
    By toothandnail in forum MetalWork Discussion
    Last Post: 10-01-2012, 10:34 PM
  3. Quote for wood work, balsa and plywood, central PA
    By pilotarix in forum North America RFQ's
    Last Post: 06-09-2012, 02:05 AM
  4. Advice for holding and cutting thin plywood
    By atwooddon in forum WoodWorking Topics
    Last Post: 12-21-2009, 06:38 AM
  5. Hold Downs/Vac Table for Balsa
    By rjfurness@bigpo in forum DIY CNC Router Table Machines
    Last Post: 08-27-2009, 09:22 AM
