586,898 active members*
3,013 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Restart of integrex eia program with dual turrets
    Jan 2007
    5
    We've just acquired an Integrex 100-IIIst machine with a lower turret that we are programming in eia. We haven't figured out how to do a restart yet. Normally we would call up the eia program as the current work no., curser down to where we'd like to start in the program and hit the "Restart2 nonmodal" button. Then start running.
    Our experience so far has been that the machine gets confused and both turrets start running at the same time.
    Anyone using eia programs that has a procedure for successfully restarting?
    Apr 2005
    19
    What control is on that Integrex, I had heard that there is a bug in the Matrix controls for EIA restarting on Integrex Mark IV machines......
    Jan 2007
    5
    This has the MTPro control.
    Apr 2005
    19
    have you tried using the restart on the main softkey menu???
    make sure you restart at a tool index for a safe start.
    when you hit restart, hit enter again to write the same program you are using for the Sub-Program (first line)
    then enter the N number for sequence number
    Block number will = 1 to start on that N# line (2 will be the line after N#, 3 will be the second and so on)
    enter 1 for the repeat # times
    and away you go! give it a try
    -S
  1. Mazak Integrex 200 III St ISO/EIA
    By maramb in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-28-2007, 09:41 PM
  2. Controller Restart problem!
    By VB IT in forum CNC Machine Related Electronics
    Last Post: 02-25-2007, 09:48 AM
  3. Integrex IV help
    By Demon440 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-19-2007, 08:21 PM
  4. integrex 50 YB ISO Programming
    By Batman in forum G-Code Programing
    Last Post: 12-13-2006, 12:47 AM
  5. haas floppy dnc restart
    By bytecolor in forum Haas Mills
    Last Post: 10-19-2006, 01:31 PM
