586,829 active members*
3,295 visitors online*
Results 1 to 8 of 8
    Jun 2010
    26
    Question Editing a canned cycle?
    Is it possible to edit a canned cycle? I'm working on an old 16i-M control and the G83 pecking cycle is horrible. Every peck starts .1" above the previous depth. This is consuming large amounts of time when I'm trying to do .050" pecks in a 1.5" deep hole. If I could change it to start .005" above the previous level, that would make this cycle nearly 3x faster. I'm aware that I could write my own macro - but that's not really a solution. I want this fixed at the machine, not the post, if it's possible.
    pearls ain't free
    Apr 2005
    629
    Re: Editing a canned cycle?
    Cavi,
    Look in your parameter manual. There are a couple of parameters that can fix this problem.
    Chris D
    1792
    Check parameter 5174
    (I am not very sure because I do have the manual in front of me)
    1792
    The unit is 0.0001 inch in inch mode, in IS-B.
    So, a value of 100 means 100 x 0.0001 inch = 0.01 inch
    2932
    I believe you're looking for parameter 5114 and 5115. But, as Chris D suggested, look in your parameter manual for a more detailed description.
    Oct 2013
    153
    That is how a typical G83 cycle works . If you need a every cut to start above 0.005" then you have to use a different cycle like G73
    Oct 2013
    153
    1792
    5114 for for G73, and 5115 for G83
    G73 for partial retraction, and G83 for full retraction.
    G83 is used when chip removal is difficult (e.g., in a small diameter hole, with a large L/D ratio)
    G83, however, is not too slow, because the inward motion up to the defined clearance (5115) is at the rapid rate; feed motion starts after that.
    If you have access to operator's manual and parameter manual, you can have such information in a minute.
  1. Canned Cycle
    By Rob66 in forum Okuma
    Last Post: 01-13-2024, 10:55 AM
  2. G68 canned cycle
    By ton-engineering in forum G-Code Programing
    Last Post: 09-28-2016, 04:22 AM
  3. canned cycle?
    By Cartel, LLC in forum Haas Mills
    Last Post: 09-27-2010, 04:06 PM
  4. Canned Cycle Help
    By vanbry in forum Okuma
    Last Post: 12-15-2009, 12:48 AM
  5. G76 Canned cycle
    By Stebedeff in forum Fanuc
    Last Post: 02-07-2008, 06:42 PM
