586,717 active members*
3,075 visitors online*
Thread: TTS Holders
    Oct 2011
    477
    TTS Holders
    One of these holders has been through the ATC more than the other, want to venture a guess which one it is.
    gary
    Apr 2016
    109
    Re: TTS Holders
    How many times has that tool been put in and out of the spindle?
    Maybe you are just proving that the shanks should be fully tapered so they center easier? :P
    I mean, that clearly shows how much misalignment is happening with every tool change.
    Oct 2011
    477
    Re: TTS Holders
    Lots!!
    ATC is likely not that bad. Manual changes likely cause most of the wear.
    7063
    Re: TTS Holders
    I have TTS holders I've used for near 10 years. I have one set I've used for ATC torture testing, that set having done, literally, many,many tens of thousands of toolchanges. Not one of them has anything even approaching that kind of wear. In fact, the shanks show no visible wear at all.
    Ray L.
    Dec 2010
    1230
    Re: TTS Holders
    That shank wasn't properly hardened. It was soft to wear in such a manor. Knock off, of maybe made on Friday... Fridays in China make for solf Chinesium.
    7063
    Re: TTS Holders
    Quote Originally Posted by WOTDesigns View Post
    Excellent point! All of mine are hard as he11! In fact the Darkon ones are even harder than the genuine Tormach ones.
    Ray L.
  1. are mt3 holders repeatable height holders?
    By neptunier in forum CNC Tooling
    Last Post: 01-01-2017, 01:18 PM
  2. Interesting Observation on ER20 Collet Holders vs. Set Screw Holders
    By EvolveES in forum Tormach Personal CNC Mill
    Last Post: 03-17-2015, 10:45 PM
  3. Tool Holders
    By pdxme in forum Mechanical Calculations/Engineering Design
    Last Post: 06-03-2010, 08:01 AM
  4. Best cat 40 holders for the $
    By shane45 in forum MetalWork Discussion
    Last Post: 04-10-2006, 04:06 AM
  5. Pen holders
    By sol in forum DIY CNC Router Table Machines
    Last Post: 03-03-2005, 12:49 AM
