586,773 active members*
9,293 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Changing drive inverter from Yaskawa G3 to Yaskawa f7
    Feb 2015
    Any help switching out Yaskawa G3 inverter to Yaskawa F7 on Partner 6 mill, would be appreciated. Wiring diagrams or parameters needed. I actually have an electrical engineer from work coming over to do it but I have noticed there are some very smart people on here and thought maybe somebody may already have done it. This is sort of a reconnaissance mission and I would like to make sure the tool changer works.
    Jul 2010
    548
    Re: Changing drive inverter from Yaskawa G3 to Yaskawa f7
    Changing out drives can be challenging.
    1. mark all existing wires and what terminal they are at on the existing drive.
    use the machine electrical manual and note the function of that wire and compare to the new drive manual.
    There are "programmable" inputs and out puts that will have to be set for "THAT" function. see the new drive manual for setting the I/O
    usually you can use the same terminal # and set that terminal I/O function. the new drive will most likely have different "ground" terminals. just move the "old" grounds to the "new" ground terminals as shown in the drive manual.
    usually Terminal #1 is fwd run and #2 is the rev run terminals.
    set motor info parameters per the new drive manual.
    Got all that done? then run the auto tune per the new drive manual.
    next time call me 1st. I will save you time and money.
    Sportybob
    Feb 2015
    Thanks for the info,
    everything worked out good.
  1. YASKAWA SGMGV-05A (450WATT) powered by servodrive YASKAWA SGDV-5R5A (750WATT)
    By graupnerhansen in forum CNC Machine Related Electronics
    Last Post: 07-12-2016, 02:11 PM
  2. Replies: 1
    Last Post: 04-21-2016, 05:38 AM
  3. Yaskawa inverter problem
    By anandhs in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-21-2007, 02:27 PM
  4. Yaskawa Inverter Problem
    By Mert-G in forum Phase Converters
    Last Post: 11-22-2007, 05:09 PM
