586,937 active members*
1,999 visitors online*
    73
    Modifying Post
    I am trying to add some line of codes into my post. I had done this previously, but had a hard drive crash and didn't have the modified post backed up.
    Basically I want a window to pop up so the operator can check the Z-shift ( which is the material thickness plus the wasteboard thickness) and manually enter the value before proceeding. I have got the window to pop up but I can't get the text to print.
    Here is a sample from my previous post that I modified.
    G70
    G90
    [WINDOW ON]
    [CLS]
    [PRINT "CHECK THE HIGHLIGHTED LINE IN THE PROGRAM TO VERIFY"]
    [PRINT "THAT THE CURRENT ZSHIFT IS CORRECT"]
    [PRINT "IF THE THICKNESS IS NOT CORRECT, PLEASE CHANGE TO CORRECT"]
    M00
    SET ZSHIFT=0.250 (WASTEBOARD THICKNESS+MATERIAL THICKNESS)
    This is what I am getting right now.
    G70
    G90
    [WINDOW ON]
    [PRINTCHECK THE HIGHLIGHTED LINE IN THE PROGRAM TO VERIFY]
    [PRINTTHAT THE ZSHIFT IS CORRECT]
    M00
    SET ZSHIFT=.25 (WASTEBOARD+MATERIAL THICKNESS)
    Here is what I have in the post. I need to get the quotation marks added:
    n,measure_mode
    n,absolute_coord
    n,"[""WINDOW ON""]"
    n,"[""PRINT" "CHECK THE HIGHLIGHTED LINE IN THE PROGRAM TO VERIFY","]"
    n,"[""PRINT" "THAT THE ZSHIFT IS CORRECT""]"
    n,"M00"
    n,"SET ZSHIFT=.25"" ""(WASTEBOARD+MATERIAL THICKNESS)"
    n,"[""WINDOW OFF""]"
    Zach
    Apr 2008
    1577
    Re: Modifying Post
    The quote variable is what you want to use.
    Code:
    "[","PRINT ",quote,"CHECK THE HIGHLIGHTED LINE IN THE PROGRAM TO VERIFY",quote,"]"
    That should do the trick!
    Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
    73
    Re: Modifying Post
    That worked great.
    What would be the best way to add a space in a line?
    Zach
    Apr 2008
    1577
    Re: Modifying Post
    Kinda crude but literally just programming a space if necessary (you can see I added one after PRINT above):
    Code:
    You can play with default_add_spaces but sometimes it doesn't really do what you need.
  1. Modifying 5 axis post
    By carbidecraters in forum Mastercam
    Last Post: 10-23-2011, 12:26 AM
  2. Modifying a post
    By MikeA in forum Mastercam
    Last Post: 11-25-2010, 08:09 PM
  3. Modifying Post Processor For my needs.
    By blakemachine in forum Post Processors for MC
    Last Post: 08-21-2009, 05:56 AM
  4. Need a little help with modifying my post .
    By hall6ppc in forum Mastercam
    Last Post: 07-30-2009, 05:33 PM
  5. Modifying 4th axis post
    By weirdharold in forum Post Processors for MC
    Last Post: 02-16-2009, 04:53 PM
