586,547 active members*
3,228 visitors online*
Thread: Problem
    Sep 2017
    Problem
    How to design this furniture leg? Anyone can explain clearly? it is very hard...
    http://www.cnczone.com/forums/attach...d=374198&stc=1
    Jan 2008
    5
    Re: Problem
    Hi Masoudex,
    I would make this using a sweep 2 rails command.
    Make open vectors to follow the curvature in the Y axis (according to the photo positioning), then make a few profiles in the X axis. Run those as a two rail sweep,
    More views of the leg would be better, isometric preferred. You probably need to make this in a few parts then surface blend them together and join.
    Let me know if you need more assistance on this. If you do, I'll need to see an isometric drawing so that we get all views related to this shape.
    Cheers,
    Bruce
    Sep 2017
    Re: Problem
    Quote Originally Posted by asbestosfriend View Post
    Hi Masoudex,
    Cheers,
    Bruce
    Thanks Bruce. I will do what you said and tell the result.
    Mar 2010
    99
    Re: Problem
    I made similar looking legs.
    Attachment 374648
    Attachment 374650
    This one was created by 2rail sweep, then surfaces was joined.
    3 rails, about 6 profiles.
    But yours a bit complex. I never made forms like this, but this one uses same algorythm:
    Attachment 374652
    Lower front part of this leg was made by curve network, all other with 2rail sweep.
    It's simple.
    Sep 2017
    Re: Problem
    Quote Originally Posted by Melkiades View Post
    http://www.cnczone.com/forums/attach...d=374648&stc=1
    http://www.cnczone.com/forums/attach...d=374650&stc=1
    http://www.cnczone.com/forums/attach...d=374652&stc=1
    It's simple.
    Thanks dear @melkiades.:wave:
  1. Fadal Idler problem. Rpm pulse problem
    By complextool in forum Fadal
    Last Post: 10-07-2016, 06:28 PM
  2. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  3. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  4. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  5. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
