On a windows computer I am trying to send a text file in hyper-terminal. Does anyone know how it works? Any set up help you can give would be great!!
Are you sending the file by modem, or to another device wired to the PC?
Sending file to my machine from pc.
what type of machine and control do you have
and are you loading the full program to your machine or drip feeding
I have a Hurco KMB1 w/bx controller. I think it will need to be drip fed.
I have never drip fed from Win HT, but maybe this will help (I only use Win HT for batch).
Com settings must match machine port settings.
Set MCS to "receive"
In Win HT select "transfer" then "send text file" browse file to send - this file will be .txt extension.
www.integratedmechanical.ca
Hi mmachining,
You can also try using an NC package if you are looking to see if it works, the following link is for a 60 day trial for a dnc package called nccom, it worked wonders for us It has an auto setup feature which will detect your machine port settings.
http://www.abmts.co.za/index.php?opt...d=33&Itemid=49
