586,594 active members*
2,774 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Machining some chunks of 6061
Results 1 to 7 of 7
    Mar 2011
    480
    Had a job requiring some large(for me) chunks of aluminum. Stock was 9" diameter x ~3.1" thick, 19 lbs. I wanted to come up with a process that wouldn't take forever on such a small mill. I also needed a tool that could stick out > 3.5" from the spindle face without chattering like crazy. Thought I'd share this. I got a 3/4" clamp collar from mcmaster carr to clam directly on a 3/4" shank tool (iv'e done this before, but not on a tool this long). I wanted to use a 3/4" tool to increase rigidity sticking that far out. The tool is a .787" diameter,3/4" shank ABtools shear hog single flute cutter with a 6" long shank cut down to 5". I found the happy place for cutting parameters was around 2.95 cu"/.min. .1" DOC .59" WOC 50"/min. You can certainly push this tool harder, but at that length of stick out this seems to be the sweet spot where I can walk away(this tool is really loud) and let her rip. I bored the I.D. for a sleeve bearing. The interior mating part, I left .003" stock from roughing with the shear hog and used an extended reach 1/2" end mill to finish the walls. Came out great, now I gotta make 3 more.
    Aug 2007
    359
    Re: Machining some chunks of 6061
    Very cool. Was the clamp collar used to make the shear hog into a pseudo-TTS tool? What rpms were you running the shear hog at with that doc/woc? Thanks!
    Don't have to be too bright to be me
    Mar 2011
    480
    Quote Originally Posted by mklotz70 View Post
    Yes,
    The collar provides a stop to meet the face of the spindle. It also provides a short guage length to minimize stickout. It also allows you to adjust the length of the tool. You can choke up on the tool if you don't need to cut deep.
    My cutting parameters were 6000rpm, .1" deep, .59" wide and 50 IPM.
    Aug 2007
    359
    Thanks! It was the rpms I was missing.
    May 2009
    327
    This seems crazy to me . 1"doc, .59"woc at 50ipm? I can bog my spindle at .5"doc, .1"woc at 40ipm with a 2 flute 3/8" HSS. I am assuming .059 woc and still seems like a lot!
    -Keith
    7063
    Quote Originally Posted by keithmcelhinney View Post
    -Keith
    0.1" DOC
    Ray L.
    May 2009
    327
    My eyes are going...
  1. Parts RFQ Machining 6061
    By hoju1301 in forum Employment Opportunity
    Last Post: 07-10-2015, 04:05 PM
  2. machining 6061 aluminum
    By conlimon in forum Benchtop Machines
    Last Post: 07-10-2015, 04:00 PM
  3. Simple 6061 Machining RFQ
    By Hellbringer in forum North America RFQ's
    Last Post: 11-02-2013, 03:10 AM
  4. large size aluminium(6061) machining
    By sharathchandar in forum MetalWork Discussion
    Last Post: 07-23-2008, 02:57 AM
  5. warpage machining 6061
    By nightshift in forum MetalWork Discussion
    Last Post: 10-23-2007, 02:02 AM
