586,847 active members*
2,307 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > 1000W high speed IPG fiber laser cutting machine - No Longer Available
    Jul 2014
    147
    Why choose EETO-FLS3015-1000W (IPG)?
    ?High Performance Yaskawa Motors fixed to a gantry and cross slide structure
    ?Superior edge quality plus high quality cutting head
    ?High precision driven box using World Leader-Top Quality Rack&Pinion Drive Technologies and Gearbox
    ?World famous IPG laser generator
    ?Direct laser control with PWM (Pulse width Modulation?
    ?5.0?and 7.5?Focus length high pressure lenses with Digital Focus Adjustment
    ?Automatic Gas Assist System
    ?Advanced Cutting Head anti-collision device
    ?Pallet shuttle system with two 3000mm by 1500mm working pallets
    ?Windows? Driven Software with materials Parameters Database
    ?Fully interlocked Safety Enclosure on cutting table
    ?Advanced Metal Cutting Post Processor software
    Advantages
    ?Adopt State-Of-Art Crossbeam and Light Weight Material
    ?Integral welding technology ensure longer constant stability and longer life
    ?The whole frame is finished through Temper Treatment as well as Vibration Test
    ?Dual-Driven Gantry Structure, stable and Excellent motion performance
    ?High Speed & High Acceleration
    ?Adopt the Best Parts from China and overseas
    ? Standard Configurations of EETO-FLS3015
    Major Configurations Content Brand
    Laser Generator Optional IPG
    Laser Cutting Head Manual Focus
    Auto Focus (Optional) Raytools, Switzerland
    Height Controller Capacitive transducer BOCHU, China
    CNC Controller Cypcut
    Professional Laser Cutting Software Fscut
    Speed Reducer SHIMPO SHIMPO, Japan
    Rack and Pinion YYC YYC, Taiwan
    Linear Guide TBI TBI, Taiwan
    Proportional Valve SMC SMC,Taiwan
    X/Y Drag Chain Domestic Cangzhou, China
    Shield Cover Domestic Cangzhou, China
    Industrial Water Chiller Domestic Tongfei, China
    Industrial PC and LCD Screen Domestic Shenlanyu, China
    Voltage Stabilizer Domestic FATO,China
    ? Technical Data of EETO-FLS3015 Series Fiber Laser Cutting Machine
    Total weight Tons 6
    Total Electrical Power Consumption Kw 11
    Laser Type Famous fiber generator
    Laser Wavelength nm 1070
    Resonator Power w 500 700 1000 2000
    Fiber Core diameter um 100
    Maximum Cutting
    Thickness Mild steel mm 6 8 10 16
    Stainless steel mm 3 4 6 8
    Aluminum mm 1.5 2 3 5
    Net Cutting Diameter mm 1500*3000
    X.Y Axis Drive system Rack and Pinion
    Z Axis Drive System Ball screw
    Z Axis stroke mm 130/230
    Maximum Simulation X,Y Axis Speed(Idle speed) M/min 80
    Maximum Acceleration X,Y Axis Speed G 0.8G
    Position Accuracy mm/M 0.03
    Repeatablity Accuracy mm/M 0.05
    Cooling Style water
    Bearing Weight kg 1000
    Assistant Gas Oxygen,Nitrogen, Compressor Air
    Dimension MM 4300*3200*1700mm
    Continuous Working Time Hrs 24
    Material Thickness(mm) Cutting Speed(mm/s) Recommend Gas
    Carbon Steel 1 300 Air
    2 130 Oxygen
    3 55 Oxygen
    4 36 Oxygen
    5 25 Oxygen
    6 21 Oxygen
    8 16 Oxygen
    10 12 Oxygen
    Stainless Steel 1 350 Nitrogen
    2 150 Nitrogen
    3 45 Nitrogen
    4 25 Nitrogen
    5 16 Nitrogen
    6 10 Nitrogen
    List Date: 9/20/2017
    For more info, click here to view the original listing: 1000W high speed IPG fiber laser cutting machine
    On Sale For: $72,000.00
    Oct 2005
    89
    Re: 1000W high speed IPG fiber laser cutting machine - No Longer Available
    need the operation manual for Tongfei Water Chiller TFLW-1000WDR-03Z-1225
    can you share
    thanks.
  1. Fiber Laser cutting machine metal cutting 500w 700w 1000w 1200w 2000w 3000w
    By DamonQ in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-18-2017, 04:07 AM
  2. Replies: 0
    Last Post: 11-26-2015, 04:17 AM
  3. 1000w fiber laser cutting machine cut 6mm steel
    By Lasersolution in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-16-2015, 12:09 PM
  4. 1000W fiber laser cutting machine of GN Laser
    By gnapple in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-16-2015, 10:26 AM
  5. Replies: 0
    Last Post: 08-07-2014, 03:04 AM
