586,588 active members*
2,714 visitors online*
Results 1 to 8 of 8
    Aug 2006
    673
    Spindle indexing
    does anyone know if there is a way to control angular indexing of the spindle with mach3 lathe? Say I wanted to be able to broach gears or something on my lathe, is there a way to index the spindle like a rotary axis?
    Edit...
    I realize that's a broad question. So more specifically, is there a way to add a third axis to the screen set? I can handle the rest if I can get a step and dir signal to output from mach3L
    Re: Spindle indexing
    If you aren't using it as a lathe, just set up a Mach3 mill configuration.
    Aug 2006
    673
    well i am using it as a lathe as well. I'd like to be able to do all the operations in a single program.
    Apr 2009
    125
    Just finishing off a few details on my Mach3 Lathe with the spindle acting as an A Axis, will be posting a video on YouTube in a week or 3.
    I had to replace the spindle motor on my lathe, due to lack of power. due to lack of space, I fitted a Chinese AC Servo motor (Best thing I ever did)
    Mach3 lathe can be adapted quite easily to 3 axis, with the spindle acting as "A" axis. You just need the motor and a couple of relays.
    Happy to share details if it helps
    Aug 2006
    673
    Quote Originally Posted by Stutank View Post
    looks like I'm a bit late to this party, but I'd love to see details. I'm getting back into my lathe build, and this is really something I'd like to do.
    Apr 2009
    125
    CS900 - Assuming you have the cheap (but very good) Chinese AC servo motor all setup as your lathe spindle motor (Control mode = 2 for speed mode). just change Control mode to 4 which is Position/Velocity Mode. This will allow to move from velocity mode (Simple lathe spindle control) to Position mode ("A" Axis indexing) via the state of Sigin2 port (Sigin1 usually = Servo enable) Sigin2 (Parameter # 53) should be set to 14 for Cmode.
    On the Mach3 end of things, using mach3screen.exe you need to add the required visual elements (I can send you a copy of lathe screem with these mods). The final requirement is for Mach3 to switch modes under program control, I use M111.m1s and M112.m1s which can be called from program and simply contain the line ACTIVATESIGNAL(OUTPUT3) for M111 (A Axis) and DEACTIVATESIGNAL(OUTPUT3) for M112 (Spindle). Output3 is connected to a relay to control Sigin2.
    I use a second line as above except OUTPUT4 to control a milling spindle in the toolpost if required (if plugged in that is).
    This should allow what you want, allowing all functions you require from Mach3Lathe + 1 Gcode program. Also good for CNC springwinding etc.
    Hope this all helps, let me know if additional details required.
    Aug 2006
    673
    thanks, Currently I have an AC motor with a VFD for the spindle, but I may upgrade to an AC motor in the future for this functionality. thanks!
    Apr 2009
    125
    CS900. Spindle indexing certainly needs an AC Servo motor, Mine gives 0 to 2500 rpm with good torque right down, and 10,000 pulses per revolution in Positioning mode.
    The perfect spindle motor, and priced similar to a vfd + 3ph motor.
  1. Indexing Headstock Spindle
    By ericdwilso in forum Vertical Mill, Lathe Project Log
    Last Post: 06-27-2018, 09:24 PM
  2. spindle indexing
    By JOE610 in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2013, 12:33 AM
  3. Spindle indexing 840D
    By botha.y in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 02-14-2013, 01:35 AM
  4. Indexing Sub Spindle on Citizen M32
    By kkiphart in forum CNC Swiss Screw Machines
    Last Post: 11-24-2010, 04:01 PM
  5. 10T spindle indexing
    By guhl in forum Fanuc
    Last Post: 10-17-2007, 02:00 PM
