587,204 active members*
2,874 visitors online*
Thread: mach 3
    Sep 2017
    mach 3
    I've built a plasma table using 2 stepper motors on gantry for the xaxis . X and A are slaved together and and tried to reverse the A motor and X with no luck .whether I check the reverse tab or no the motor only runs one direction and my y axis is the same situation
    Jul 2005
    2415
    Re: mach 3
    Rewversing a motor just changes the direction it runs in relation to the DIR signal. Properly setup motors will run in either direction when you jog the oppose way. reversing just reverses both directions. If you can't make the mtors move BOTH ways on the axis (even if its is the wrong way in realtion to the DRO readouts) then you have a signal problem. The DIR signal has to change froom high to low (or low to high) to change the motor direction of travel
    May 2005
    1397
    Re: mach 3
    Just swap the phase wires on the motor. Power off first, of course.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. Mach 3 parts counter and hour meter mach...
    By [email protected] in forum Mach Software (ArtSoft software)
    Last Post: 01-31-2015, 04:18 AM
  2. Mach 3 - Driver Test results VMWare player (XP -> Mach 3)
    By itolond in forum Machines running Mach Software
    Last Post: 04-07-2014, 01:32 PM
  3. Replies: 3
    Last Post: 05-14-2010, 09:16 AM
  4. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
