586,501 active members*
2,734 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Way to monitor Backup Battey Voltage?
    Jan 2004
    539
    Just got the low battery alarm so I installed the dual battery kit from Haas that I got a while ago. Is there a setting or parameter that would show the voltage?
    I would love to see what the control is seeing as far as current battery voltage.
    If you ck the voltage on the factory soldered battery it is 2.8ish, when you plug in the dual kit it goes up to 3.02ish. I would rather not desolder the old battery but I wonder if it is messing with the new battery's?
    Gary
    Jan 2017
    25
    Re: Way to monitor Backup Battey Voltage?
    The instructions state to REMOVE THE OLD BATTERY, the cell is dead and your putting a charge to the dead battery, you dont need to desolder it just cut it off with a side cutter (dont hit any wires) with your new battery pack installed, remove the old battery from the Maincon or processor. of course do a back up before doing this, only way to check it is at the new battery board with your volt meter (You will see a + and - on the board) and when the voltage gets below 3VDC replace the batteries on the board with the power on and you will not have any issues
    Jan 2004
    539
    Yep confirmed no internal meter that you can access.
    Gary
    Feb 2010
    1184
    Quote Originally Posted by Tlarson View Post
    Agreed, you will want to remove the original board mounted battery.
    Jan 2017
    25
    Quote Originally Posted by haastec View Post
    I ran into this once at a customer. It was before the replacement boards came out and the tech installed a jumper battery and left the old one on the board, and the original battery was HOT! I have done this in the past but removed the old battery and didnt solder the new one on just used the jumper\.
    Jan 2004
    539
    I did the jumper battery about 2+ish years ago when the original failed. ( no warning no alarm) Luckily I lost nothing as I had just done a regular backup.
    But I left the old battery in as I was going to re solder a new one. But then Haas came out with this kit so I got one for all the machines and they have been in a box waiting until Wed when I got the alarm
    So I agree the old battery is reducing the life of the new ones.
    Gary
  1. Help..Stuck at relay ext dc voltage missing but dc voltage OK ?
    By Dirky in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2021, 06:39 PM
  2. U10M spindle load monitor and monitor mode
    By myhäje in forum Okuma
    Last Post: 02-21-2017, 08:45 AM
  3. High voltage power supply, low voltage perihperals
    By feechl in forum CNC Machine Related Electronics
    Last Post: 01-07-2014, 02:12 AM
  4. Precix 9100 Controller - VI voltage issue Voltage range only 6.5 to 10Volts
    By wdysf150 in forum Controller & Computer Solutions
    Last Post: 08-15-2013, 08:24 PM
  5. FUSE MONITOR. NIFTY, doubles as Power On indicator. WORKS ANY VOLTAGE AC/DC
    By gort in forum CNC Machine Related Electronics
    Last Post: 07-31-2013, 12:08 AM
