Originally Posted by
SCzEngrgGroup
130F max temp is NOT a problem. A "squeal" is most likely not the bearings, but the belt or something else. If the spindle feels smooth when turned by hand, it is very likely ok. I would do a lot more testing before tearing into it.
Ray L.
I have to agree with Ray. There's probably no need to tear the spindle down.
I had a service guy tell me a long time ago that the biggest reason for excessive heat is "too much grease".
