586,655 active members*
3,562 visitors online*
    Removing power from a Interact 412
    When I remove power and air from my Bridgeport Interact 412, the spindle drops down.
    I have been told I have to place a wooden block under the spindle before I shut it down to prevent this.
    I have heard opinions on both sides....that this is normal and it is not normal. I am looking others who have an Interact 412 and their experience with this.
    As a sidenote...if I leave the air on the spindle will still drop down when power is removed.
    May 2016
    526
    Re: Removing power from a Interact 412
    Sounds like your brake is not holding on the Z axis motor
    Any thoughts on how I can verify the operation of the brake or common failures with it?
    Feb 2012
    42
    Quote Originally Posted by CastleWorks View Post
    The brake is adjustable.
    You can stand on the table and reach the Z servo above the head. You shouldn't be able to turn it by hand when the power is off
    Sep 2005
    250
    It is common the spindle drops about .020 when removing power from both my 412 machines. I believe it says this in the manual.
    Jan 2013
    8
    Does anyone have a copy of the parameters and pc parameters ?
    For the Interact 412F.
  1. Power Drawbar Build on Interact 1 mk 2
    By mflux_gamblej in forum Bridgeport / Hardinge Mills
    Last Post: 06-21-2013, 11:30 PM
  2. Removing ballscrew Bridgeport Interact II
    By Shanghyd in forum Bridgeport / Hardinge Mills
    Last Post: 04-16-2013, 03:31 PM
  3. bridgeport interact 1 cant get power to come on
    By thomasmc in forum Bridgeport / Hardinge Mills
    Last Post: 09-15-2009, 05:35 PM
  4. Interact 1 Power Input Question
    By rkdygert in forum Bridgeport / Hardinge Mills
    Last Post: 09-06-2006, 06:41 PM
  5. Series 2 Interact Power Drawbar
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 07-14-2006, 04:56 PM
