586,845 active members*
2,292 visitors online*
IndustryArena Forum > CAM Software > Mastercam > X Editor simple question
Results 1 to 6 of 6
    Jan 2016
    40
    I'm running old X6. When I post out it goes to X editor, then after I hit save X editor saves it to an NC file that I can open in notepad. What if I want to open the file back up in X editor? I can't even find X editor anywhere to open by itself? Do you open it through the session of mastercam you've already got open?
    Sep 2007
    100
    Re: X Editor simple question
    Right mouse click on the file name, from the drop down menu select OPEN WITH, then select Mastercam X Editor.
    Alternatively, from the drop down menu you can choose DEFAULT PROGRAM so that when you double click a file name of the same type it automatically opens in Mastercam X Editor.
    Jan 2016
    40
    X editor doesn't come up when I try open with. The drop down "other programs" doesn't show it, and I searched in "browse" with no results.
    Sep 2007
    100
    Try this,
    Open MCX6, from the file menu drop down choose EDIT / OPEN EXTERNAL, navigate to your NC or CNC file and double click on the file name.
    I did this and the file I chose opened in MC X editor.
    Sep 2007
    100
    Here is a way to get a shortcut on your desktop.
    program files\mcamx6\common\editors\mastercam.
    Look for MCXSTART.exe
    Right click on it
    Select send to
    Select Desktop (create shortcut)
    Apr 2003
    3578
    The default editor in Mastercam X6 is the Mastercam editor or called sometimes the X editor. the edtior has been repelaced with Code Export these days. I suggest setting to the Cimco editor as your default.
    Now all editors are located on the C: drive as told here here. C:\Program Files\Mcamx6\Common\Editors.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. Preditor editor question
    By bb218 in forum BobCad-Cam
    Last Post: 02-13-2011, 11:24 AM
  2. MCam Editor DNC Question
    By JMFabrications in forum Mastercam
    Last Post: 05-18-2010, 10:26 PM
  3. just a simple question
    By chrispare in forum Hobbycnc (Products)
    Last Post: 03-11-2010, 02:47 AM
  4. Simple Question Simple Answer ?
    By p3t3rv in forum Stepper Motors / Drives
    Last Post: 02-16-2006, 04:00 PM
  5. Simple question?
    By johnney0005 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-26-2005, 05:52 PM
