586,437 active members*
3,781 visitors online*
Thread: Mild Steel
    Feb 2005
    753
    Mild Steel
    When people say "mild steel" are they refering to mild steel or is there a number to it? I looked up online for mild steel and can't find it.
    Is it under cold rolled or anything like that?
    Jul 2005
    12177
    Mild steel is a general term. Cold rolled steel C1018 is mild steel, hot rolled steel is mild steel, leaded steel C10L14 is mild steel. Here is a definition of mild steel.
    Carbon steel is sometimes referred to as 'mild steel' or 'plain carbon steel'. The American Iron and Steel Institute defines a carbon steel as having no more than 2 % carbon and no other appreciable alloying element.
    Steel with between .3% and .8% carbon is Medium carbon steel and above .8% it is High carbon.
    If the steel has other alloying elements such as manganese or cobalt, etc., it is called alloy steel and if it has chromium it is called stainless steel.
  1. RFQ: Milling needed in mild steel.
    By SCCoupe in forum Employment Opportunity
    Last Post: 12-11-2006, 03:06 AM
  2. RFQ - on 1/2" mild steel plate
    By BullCreek in forum Employment Opportunity
    Last Post: 07-11-2006, 12:31 AM
  3. Plasma cutter for 3mm mild steel
    By DEEDEE in forum Waterjet General Topics
    Last Post: 01-20-2006, 12:25 AM
  4. Machining Mild Steel
    By georgebarr in forum Uncategorised MetalWorking Machines
    Last Post: 06-30-2005, 12:54 AM
  5. A Mill for milling HSLA and Mild Steel
    By deep_drill in forum Uncategorised MetalWorking Machines
    Last Post: 06-07-2005, 05:29 AM
