I keep receiving an ERROR 040 R1-R2 message when trying to perform a 2 axis profile cut. As long as I generate a 3 axis profile everything posts correctly and the cut paths run great. If I want to cut a 4" circle using the "Generate 2 axis" option in BobCad the post appears to generate correctly but when executed I get the ERROR 040 message. According to my fagor users manual, the 040 error reads "The circle programmed does not pass through the defined end point (tolerance 10 microns, 0.005 inch). The arc defined by G08 or G09 does not exist". I have no idea what this means and with it being such an old controller there isnt much help available. Can anyone provide any insight on a solution for this? The post below was generated for a 4" circle using a 2D ramping tool path, .125" depth of cut. Running this file will throw the 040 error.
%00003
N10 G90 G80 G70 G40 G17
N20 S297 M03
N30 G00 X-0.8274 Y-2.3591
N40 Z0.2
N50 Z0.1
N60 G01 Z0. F200.
N70 G17 G03 X2.5 Y0. I0. J0.
N80 X-2.5 Y0. I0. J0.
N90 X2.5 Y0. I0. J0.
N100 G00 Z0.2
N110 X-0.8274 Y-2.3591
N120 Z-0.15
N130 G01 Z-0.25 F200.
N140 G03 X2.5 Y0. I0. J0.
N150 X-2.5 Y0. I0. J0.
N160 X2.5 Y0. I0. J0.
N170 G00 Z0.2
N180 X-0.8274 Y-2.3591
N190 Z0.1
N200 G01 Z0. F200.
N210 G03 X2.5 Y0. I0. J0.
N220 X-2.5 Y0. I0. J0.
N230 X2.5 Y0. I0. J0.
N240 G00 Z0.2
N250 X-0.8274 Y-2.3591
N260 Z-0.15
N270 G01 Z-0.25 F200.
N280 G03 X2.5 Y0. I0. J0.
N290 X-2.5 Y0. I0. J0.
N300 X2.5 Y0. I0. J0.
N310 G00 Z0.2
N320 Z1.
N330 M05
N340 M30
