Originally Posted by
cncjoy
Is there a simple fix to this problem?
We're using a Fanuc 6M control to run a 3 axis simultaneous (X,Y & Z) surface milling program at a 2000mm/min feedrate.
The program is made up of thousands of small (1mm) X,Y,Z movements.
In practice, the machine never reaches the programmed feed because it is always accelerating and decelerating between each co-ordinate.
We are not working to tight tolerances (+/-0.2)
Is there some way of either configuring the control or modifying the CNC program so that the moves are "smoothed" out in order to achieve a higher feed rate?
I'd be very interested to read any suggestions you have.
If you program a G98 (?) at the end of each linear feed line it might get rid of the pauses between moves. i'm not sure if it is G98 though.
Dave
Schneider Machine
A force of one
