586,664 active members*
4,043 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Conversion to Imperial...
    Mar 2010
    621
    I have a simple drawing in Metric from AutoCad and I want to mill it in Inches but when I import the .dxf into MasterCam its still is in metric even though the scale says inches, any ideas?
    When I create toolpath's its obvious its still in metric...
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    Apr 2013
    1899
    Re: Conversion to Imperial...
    Maybe not the right solution, but I have the opposite problem. I always create drawings in metric in my CAD software (not AutoCAD), want to mill in metric but when I open the DXF file it always says inches in my CAM. The easy solution for me is that before I import a DXF file I open it in a text editor, for example in Notepad, look for the variable group $MEASUREMENT and change the second parameter from 0 to 1. I guess in your case it must be changed from 1 to 0. Try it if this solves your issue at least temporarily. The DXF files are simple text files, change only the $MEASUREMENT and don't touch anything else in the file, don't remove any space, tabs or anything else. It may not be your problem at all, but maybe worth a try. Also, I don't know how drawing scale is connected to drawing units in AutoCAD, perhaps those are different settings.
    Mar 2010
    621
    Thanks for the reply A_Camera,
    I did some more digging around I realized that even though the drawing is in metric and when applying counters that it was generating them in imperial, it just didn't feel right. So to prove it I just created a simple contour at the full depth of the part and all was good, in this case it turns out to a typical PICINIC (problem in chair not in computer)
    Have a good one.
    Adam,
    Oct 2006
    104
    Drawings have units attached to them, so when importing a drawing that is in Metric and you want to program in inches, you will need to scale the metric drawing to inches. You will do this by scaling the imported drawing by .03937, this will convert the metric drawing to inches. If you want to go from metric to inches you would use a scale of 25.4. Solid models do not have scale so you can import them with no conversion issues.
    Dec 2008
    3111
    Quote Originally Posted by seijack View Post
    Just to add...... the input boxes can utilise a equation input for greater accuracy... type in ie 1/25.4 ( =0.03937007874015748031496062992126 )
    they also can use inch input data on a metric dwg ie 1" (=25.4)
    or the reverse(metric in an inch dwg).....25mm (=0.9842519685039370078740157480315)
  1. Convert from Metric to Imperial
    By Rift in forum Solidworks
    Last Post: 05-29-2011, 01:57 AM
  2. Metric vs Imperial collets
    By JulianDR in forum CNC Tooling
    Last Post: 11-23-2010, 04:03 PM
  3. changing from metric to imperial
    By ashro in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2010, 01:13 AM
  4. Change from metric to imperial
    By cijunet in forum Mastercam
    Last Post: 12-10-2007, 06:51 AM
  5. Converting from metric to imperial
    By Pharkas in forum Mastercam
    Last Post: 05-04-2007, 04:46 PM
