Re: need help drilling a stupid hole...
1st, thanks for all the suggestions....
the thing is, I have had far less issues drilling 1/2" holes than I am having with this stupid 0.404 hole and that is confusing me and sort of pissing me off at the same time...
actually, the only issue I have ever had with the 1/2" is that it is fairly easy to stall the spindle if you push it to hard/fast...
differences that I can see is that my 1/2 drill is a proper "cnc" style jobber drill, nothing special, fairly cheap black oxide which I cant imaging is of any benefit for aluminum... and my #Y is just your average "Titanium coated" (sure it is... looks like cheap gold paint/electroplating to me) came from a cheap set from a hardware store type drill..'
and the 1/2" is in Tormach's large chuck...
I do use flood coolant, haven't tried oil yet... but it isn't chip welding... at least not to the drill, it looks fine...
I think I will just a pre-drilling op to drill it out to 1/4" as suggested, and I will try tightening all three positions, even if that does seem odd...
NOTE:As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists.
