Hello-
I've got a Fanuc 6T control on a Hitachi Seiki 3NE-300 lathe. Recently it's developed an odd problem. It will overshoot a negative Z position by about 450 thousands when given a G0 or G1 command. Give it a positive Z position and a canned cycle, it's fine. I've swapped out main PCB's and the problem persists. Servo motor appears good, ball screw is good, drive pin and shear pin all appear good. I can work around it by putting a 450 thousand offset, but I'd like to fix it. Any thoughts?
Bob-
