586,655 active members*
3,985 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Profile cut for mold?
Results 1 to 12 of 12
    May 2005
    32
    I am making a mold it has a contoured bottom (hills and valleys). I'm able to clean out the bulk of mold fine using a z-level rough and two planar strategies. The problem I'm having is cleanning the side walls of the mould. I'm using a profile cut and it cleans up the sides beautifully, only it cuts right through the contours on the bottom. I've set my depth of cut to the lowest point. How can I get it to follow the bottom countours?
    I've attached a picture showing the tool just cutting the profile to 1.0625" depth which is the lowest point but it doesn't come up when it comes to a protrusion,it just cuts right through it? I've extracted a wireframe from the bottom and selected that as well as the top profile wireframe as geometry and it still just chops right through the part.
    Apr 2009
    3376
    Re: Profile cut for mold?
    what version of software and standard or pro ?
    Without a file ???
    explore 3d wireframe for tool path on the sides
    you will have to extract the geometry for the tool path from your solid model
    May 2005
    32
    I'm using v26 PRO. I've been playing with the wireframe, I select the bottom wireframe (geometry) and it ignores it. I tried some different tooling and it's coming out not to bad now but still wouldn't mind knowing the right way to do it. I've attached the file.
    Dec 2008
    4548
    Quote Originally Posted by jake76 View Post
    Hey jake. The profile operation is a 2d path and wont follow up and diwn in z. It will just follow a depth setting, which will be constant.
    It will require a 3d toolpath.
    Not at home now, but will look at your file later.
    Apr 2008
    1577
    Hey Jake, these guys have you on the right path. You have to use the edges of the solid model then offset and translate them accordingly depending on what tooling you are going to use. Then use a 3D wireframe toolpath, NOT a 2D Mill contour.
    What tool will you be using to pencil the bottom in? It has a 0.050" radius in there and I didn't see the "perfect" tool in your tool crib. I got a decent result using the 0.125" ball mill you had in there but I'd rather know for sure before going into the steps required to contour the bottom in 3D. It appears to be fairly simple in this case.
    Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
    Apr 2009
    3376
    May 2005
    32
    SBC Cycle
    I'm trying to use the existing tools we have. The smallest is 0.125", thats why it's there. I tried to go with a larger radius on the fillets but BC was pretty inconsistent in what it would let me do. I know there will be a fillet depending on the tool diameter so its not critical as long as the edges aren't sharp.
    - - - Updated - - -
    jrmach
    Whats the question?
    May 2005
    32
    jrmach
    Whats the question?
    I know my questions may seem ameteurish to you but we all started somewhere. I'm not a machinist, I'm trained in Electronic Engineering, the last time I used a CNC was in Uni for cutting PCB's so cut me a little slack.
    Apr 2009
    3376
    Had not heard from you,,,wondering if you got going,,,that's all
    May 2005
    32
    Quote Originally Posted by jrmach View Post
    We are making a jig for the table now. We ran into a hiccup on the tool change so we just bought the screenset 2010 from a forum member here. Even the first strategy z-level rough was giving better results then what was shown in the simulator. When we get the table jig up, I can test how well the 0.125" bit clears the side. I'm hoping to be able to get the jig table up (mdf board with a hole pattern over the work area) on monday then we can proceed.
    Apr 2008
    1577
    Sorry I didn't get back for a while. Awesome, it's not to bad to adust the path for the tool you have if the radius doesn't matter.
    Ok so I learned this trick on the old old BobCAD forum and it was for lathe turning (to account for Tool Nose Radius). Once I understood what was going on I learned how to do it in 2.5 axis and 3D as well.
    So the short version is, you want to offset the bottom "profile" by the tool radius (the tool you will be using). Then translate that offset profile down in Z by the same amount. You have to translate it back down because BobCAD's 3D engrave function works only by the tip of the tool. This will be the geometry for the 3D engrave function.
    Here is a pic for a visual: (And don't forget to watch the walls of your mold too. I grabbed the edges of your model created by the 0.050" fillet. I had to move the profile off the wall of the mold to avoid a gouge, there is no diameter offsetting in the 3D engrave function! It just follows the path.)
    May 2005
    32
    Thanks SBC for the help.
  1. Replies: 0
    Last Post: 08-29-2014, 12:45 PM
  2. Replies: 0
    Last Post: 07-13-2012, 08:27 AM
  3. Best way to prep mdf mold for making female mold
    By konalure in forum Moldmaking
    Last Post: 10-29-2009, 02:48 PM
  4. Making a positive mold from a negative mold - how?
    By SRT Mike in forum Moldmaking
    Last Post: 03-29-2007, 10:30 PM
  5. ID Mold Threading profile
    By Wiseco in forum G-Code Programing
    Last Post: 07-15-2005, 09:41 PM
