586,594 active members*
3,111 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Can you use a 4th Axis as a substitute to a lathe?
    Jul 2016
    25
    I would like to start with 1/2 inch hex shafting and turn it down to 1/2 inch round shafting. I realize that the ideal tool for the job would be a metal lathe, but I do not have access to one.
    I do have access to a Tormach 770 with the 6-inch 4th axis add-on. Would it be possible to turn down the hex shafting using this setup? Perhaps by slowly turning the stock while lowering a spinning end mill? I realize that this would not be ideal, but would it work?
    Feb 2009
    152
    Re: Can you use a 4th Axis as a substitute to a lathe?
    You can buy R-8 hex collets- grip your hex material in the spindle and set up your cutting tool in a vise.
    Dec 2013
    5717
    It would work, but not the best.
    Dec 2009
    1416
    It depends on the surface you need as well. The endmill + 4th axis will leave a much rougher surface than a lathe would. As mentioned the best way would be a collet in the spindle and a tool in the vice. That would give the best surface and roundness I would think.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
    Jun 2006
    3063
    Steve Simpson's InTurn is a servo-driven 4th axis that will turn around 3,000 rpm for turning or much slower for 4th axis work. It's sort of a RapidTurn on steroids. Also much more expensive.
  1. Replies: 0
    Last Post: 12-31-2015, 05:17 PM
  2. Aspire substitute?
    By cncbcncb in forum Aspire
    Last Post: 10-24-2012, 03:14 PM
  3. Renishaw substitute
    By graemeian in forum Mach Wizards, Macros, & Addons
    Last Post: 04-23-2012, 08:50 PM
  4. Replies: 1
    Last Post: 03-11-2007, 07:16 PM
  5. Moglice Substitute?
    By cbcnc in forum Uncategorised MetalWorking Machines
    Last Post: 08-02-2003, 12:36 AM
