586,588 active members*
2,620 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > FineLine Automation > Saturn 4'x4' My Second Build the first time with Clearpath Servos
Page 3 of 3 123
Results 41 to 47 of 47
  1. #41
    Oct 2016
    236
    Re: Saturn 4'x4' My Second Build the first time with Clearpath Servos
    WhiteWolf,
    One more question for you...What size ClearPath motors did you decide to use? From the pictures, they look like they might be the CPM-SDSK-3421, but did you use 3421S, 3421D, or 3421P. Using the CNCRP 960 oz-in NEMA 34 motors as a baseline, it looks like the 3421S should be reasonable, but I wanted to check my homework with a classmate. I agree with your choice to use the high-res versions for the R&P drives. You could almost get away with a 3411S for the Z-axis, I would think.
    Robert
  2. #42
    Mar 2017
    72
    ClearPath® - Integrated Servo System (CPM-SDSK-3421S-ELN)
    I used those for all 4 with the exception of Z not being enhanced model. I stayed with the same model for the Z as per recommendation from another thread due to the pitch of the screw.
  3. #43
    Oct 2016
    236
    Thanks, WhiteWolf. That makes sense. Looks like I might actually be learning a thing or two.
  4. #44
    Apr 2010
    109
    Build looks great, hope you are making chips by now I am looking at a 2x4' unit with the steel gantry. I was hoping you might be able to give me some insight on how the steel gantry cross member is bolted to the plates it sits on. Also wanted to get your impressions of the machine over all. Would you do it all over again? Do you feel like the machine was square and true and ready to have electronics mounted without having to do a bunch of reworking of the mechanicals to get it to work right? I feel like on paper this is a great deal, but wanted to see how others are getting along with their machines AND their maker Thanks!
  5. #45
    Mar 2016
    15
    Great looking build! I'm currently looking at either a 4x4 or 4x8 Saturn 2, just curious how you like the machine a few years in?
  6. #46
    Nov 2014
    724
    We got our 2x4 Saturn in July 2016 and it's still going strong. I use it almost every day.
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
  7. #47
    Got mine in summer 2017 and has been used almost every day as well. Couple spindle upgrades and currently installing an Aluminum surface plate. I use to support High School Robotics and odd jobs including bike parts and yard signs - absolutely love it,
Page 3 of 3 123
  1. Can two clearpath servos be used to power one axis?
    By Dangle_kt in forum DIY CNC Router Table Machines
    Last Post: 06-24-2021, 03:50 PM
  2. 2nd Build (first) - Saturn CNC 2'x4'
    By difalkner in forum FineLine Automation
    Last Post: 11-11-2017, 12:56 AM
  3. Clearpath Servos for Tormach?
    By GLCarlson in forum Tormach Personal CNC Mill
    Last Post: 05-02-2017, 01:31 PM
  4. Saturn 4 X 4 build
    By sybilsurf in forum FineLine Automation
    Last Post: 03-19-2017, 01:47 AM
  5. Some advice and opinion on Clearpath servos
    By KennyPowers in forum Servo Motors / Drives
    Last Post: 09-11-2016, 09:22 PM
