586,933 active members*
2,688 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need help with old System P Model G terminal
    Feb 2012
    126
    Unhappy Need help with old System P Model G terminal
    Hi guys, I am a newb just starting to learn the earlier Fanuc Controls and have pieced together a 0MA, an OMC, and a 10TF. I am trying to learn to write/modify the ladder mainly for the operator panel and acquired the appropriate PG terminal. It powers on, and lights up some leds on the keyboard but there is no video. Nothing happens when I put in a disk and press and hold the load key. I can hear the high voltage section of the CRT working, and I can see the collapsing flash on the CRT screen when it powers down which leads me to believe the CRT is good. Power supply voltages all seem fine, looking at them with an oscope. I have reseated the socketed ICs to no avail. Is there anyone here familiar with these that could help me, or that has a working unit that could test my PCBs for me? Tennessee industrial has the boards, but they want $1500.00 for each one, and don't give any credit for the core.
    Best regards, and thanks in advance.
    I am located near Eau Claire, Wi
    Apr 2009
    1379
    Re: Need help with old System P Model G terminal
    We have such a system here that we don't need; send me a PM.
    Aug 2011
    2517
    regina: you sent me a PM but your CNCZone settings don't allow you to receive PM's so I can't reply. Set your settings to allow PMs then send me another message.....
    Feb 2012
    126
    Final determination was the rear most board that failed. I checked the eproms, cleaned corrosion and changed out some cruddy sockets but nothing changed. I was unable to troubleshoot it further.
    Ended up having to buy a parts unit off ebay and scavenging the rear board from it. Swapped out the rear board from the parts unit and it is up and running. CRT on parts unit was dead.
    Thanks fordav11 for your help!!!!!!!!!
  1. Fanuc System P Model G
    By drgbt in forum Fanuc
    Last Post: 12-20-2019, 09:07 PM
  2. Fanuc system 6M model B
    By Olsson in forum Fanuc
    Last Post: 01-29-2016, 09:31 AM
  3. Fanuc 31i model b coordinate system
    By Bhard320 in forum Fanuc
    Last Post: 04-23-2015, 03:52 PM
  4. General Numeric System P-Model G
    By Perfect Circle in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-19-2010, 07:58 PM
  5. Fanuc System P model G
    By SGARCIAM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2009, 10:20 PM
