587,006 active members*
3,233 visitors online*
Results 1 to 18 of 18
    May 2005
    2502
    What About a Gang Lathe?
    Lots of mini-lathes being converted to CNC here, but I haven't seen a real good answer to the toolchanging problem. People do mount the cutoff tool on the rear, which I guess gives you 2 tools, and there have been some complicated looking rotary changers built, but it seems like gang tooling is the easy way out and I would expect to see more of it.
    I first saw gang tooling associated with a product called the "Accu-Slide" that let you convert a Hardinge to CNC just by clamping the thing to the ways:
    The idea on a gang lathe is to use a long slide, and let the machine's X and Z motions select the tool. To select a tool, the slide moves right to clear the workpiece (no tailstock used on a gang lathe!), the tool is selected by moving the slide in or out, and then the slide moves back left to bring that tool to bear.
    Very simple! The key is going to be having long enough slide travel to carry enough tools. I learned a lot reading about gang lathes from manufacturer's web sites like Omniturn. For example, they use an 18" long slide with 10" of travel.
    Along the way, I have also mused about converting Asian machines to use linear slides. A gang tool conversion is a perfect opportunity, because you probably need to fabricate a new longer slide anyway.
    It turns out the Omniturn-sized slide would work well on my Lathemaster 9x30 lathe, so I did some sketches in Rhino to see how it might work:
    The circles show swing over cross slide and swing over apron top. If I install a 1" thick aluminum gang slide with clearance for some 12mm linear rails, I lose about 1/4" of swing over the gang slide. Given how they're used, I can live with that. I would think some pre-ground tooling plate of 6061 (or preferably 7075/Fortal) would be ideal.
    The drawing shows mounting the 12mm linear rails to the bottom of the gang slide, and then bolting the blocks to the apron. I would bolt them either side of the male dovetail, leaving that dovetail intact so I can go back to "stock" if desired. The ballscrew drives from the side, much like Ron111's Lathemaster conversion you see on another thread.
    Toolposts are attached using the single T-slot that runs along the front of the plate. One could buy commercial QCTP's like Phase II, but that's way overkill. I would make them up in the AXA size, and just use a set screw to load the tool holder against the wedge. Alternatively, you can design the holders to go right to the T-slot, but you'd have to shim to get height adjusted.
    This does not seem that hard to fabricate, yet would add tremendously to the power of you CNC lathe conversion by solving the toolchanger problem. Not sure why we haven't seen someone do it yet.
    I will look into it further when I finish my basic Lathemaster conversion, but there's lots of folks on these boards who would probably turn out a finished result a lot faster than me.
    Let us know how it goes if you decide to give it a try!
    Cheers,
    BW
    PS I will be keeping my design notebook and eventually build log on my web site here:
    http://www.thewarfields.com/cnccookb...GangSlide.html
    Dec 2003
    24223
    Quote Originally Posted by BobWarfield View Post
    Bob
    Would this not turn it into a variation of a turret lathe and defeat the purpose of purchasing a 30" lathe where you cannot use long material/tailstock
    Al.
    Albert E.
    Dec 2004
    524
    Bob,
    Me too. I have a Rivett (very much like a Hardinge 2nd op lathe), and a Max Turn (15 x 30). The Rivett has a pneumatic collet closer.
    I'd like to build something that could be used with either machine. Pick it up and move it from one to the other. I've been looking at the Omniturn website videos with envy. For my use, gang tooling is probably the way to go.
    The "plan" is to first build the table and get it running with EMC for the control system. (I'm currently using EMC on my mill.) Then I'd play with the spindle. Add an encoder, at least, so I could do threading. It would be nice to put a VFD on it and be able to do constant surface speed machining. The best of the options would be to put a servo on it. That would give the best control and allow the use of a C-axis and live tooling.
    If you look at the Omniturn site, you'll see the live tooling options they offer. Any small spindle could be mounted on the slide.
    If you decide to go with off the shelf components (rather than off the ebay components), I might be interested in working on the project with you.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    May 2005
    2502
    Bob
    Al.
    Yes and no. You can't use the gang tooling with a tailstock, or at least not unless your tailstock is motorized and will get out of the way. On the Omniturn site they have an optional tailstock that mounts to the headstock instead of the bed.
    My view is you could either start with the smaller 8x18 Lathemaster, or keep the 9x30 and use the tailstock w/o gang tooling. All you'd need to do is cut back the number of toolposts on the gang slide to 2 (one in front, one in back) when using the tailstock. When I think about how often I actually use my tailstock, this works for me.
    As long as the mountings line up on both lathes, there is no reason you couldn't move the slide back and forth as needed. If I had a big lathe, like your Max Turn or a 14x40, I would be real tempted to do both axes in an Accu-slide like setup, and then you can bolt it on to run CNC and remove it for big manual jobs.
    I did see the live tooling options and found that interesting. Live tooling really benefits from being able to run the spindle as an indexable axis. More research needed there.
    I am pricing out off-the-shelf components to see. Ballscrews are pretty cheap from McMaster-Carr and other sources. The linear rails are a lot more money. I did find some HiWin rails on Technico that were more reasonably priced. We'll just have to see. I have a lot else in the queue ahead of this, but thought I'd start the discussion while I'm in the design phase.
    Best,
    BW
    Nov 2006
    925
    We call them platen lathes over here.I don`t have one but have been looking for one for a while.Just missed a Wasino with motorised milling head a while back.I would tend to agree with Al and say they are not a lot of use for long parts as even with a tailstock you would only be able to access two tools.Ideal for short work on a series of parts.On some machines you can take the top of the slide complete with toolholders,this lets you keep plates ready set for repeating jobs,just change the collet,change the tool plate,call up the programme and of you go,no setting needed.
    The other advantage has been already mentioned in that it would be simple to mount motorised attachments to a slide which does not revolve.
    I doubt that I would ever convert a machine to platen style but if I did I would start of with a capstan (turret) lathe as they usually have a reasonably long substantial cross slide.
    May 2005
    3920
    Years ago I used a specialized lathe for optical work that was more or less a gang tooled lathe. The problem I see with this approach is the very limited range of usage for a general purpose lathe. It would be one thing to set up a lathe like this for a specific production operation or task it is another thing to expect the lathe to be continued to be used as a general purpose machine.
    Nothing bad about that of course as many a shop machine has made the transition to a tasked machine. As to your approach I don't see anything specifically wrong with it other than the aluminum and possibly the placement of the stationary bearings. The preference would be for cast iron, maybe even steel over the aluminum. You might also want three cars per side to better support the plate. These are really quibbles though.
    What is really needed from the standpoint of this hobby is a really nice indexing tool holder that is either easy to build DIY style or could be delivered at a reasonable price from a vendor. Four or five tools ought to do it. I can remember from the days just after high school coming into contact with a manual Bullard VTL which could index it tooling turret with a single gear motor. Wish I had paid more attention to what was happening there, sometimes though the secretary walking up the steps to the office was much more interesting. 25 years later I think more about indexing tools than err lubing tools.
    In any event you would think that there ought to be a low cost approach to a tool indexer for this market. Especially if a machine from the 40's or 50's could do it with a single gear motor.
    dave
    Mar 2004
    1306
    Hi Bob,
    I like your web site.
    Do you have any real production runs lined up? I see from your web site you are a Hobby CNC guy like me. On my CNC'd mini lathe, I have a single wegde type AXA tool post and about 17 tool holders (they only cost about $15 from Shars, so I get a few each time I come to the states). Once you have your offsets set up, tool changing is only a couple of second. I can see it being a PITA on a production run, buit for hobby stuff it is not such a big deal.
    Regards,
    Mark
    Dec 2004
    524
    If you have a 2nd op lathe that you want to convert to cnc, the issue is pretty simple. My Rivett turret lathe starts with essentially NO axis. It has a manual cross slide and a manual turret. So, to convert it to cnc, I have to build two axes.
    If I go with gang tooling, I still have two axes to build. The X axis is just a little longer. If I used a turret for tool changing, I would have to add a third axis -- the rotating turret. That seems like a lot more work.
    It seems to me that if I have to build two axes anyway, I might as well go with the gang tooling approach.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    May 2005
    2502
    Quote Originally Posted by lerman View Post
    Ken
    Ken, you've captured the logic that I find compelling for gang tooling perfectly. You get toolchanging simply for the cost of a longer axis, with no muss or fuss to speak of.
    You can still use your tailstock, and the only cost is that for jobs that use the tailstock, you can only use a front and rear tool, which leaves you no worse off than otherwise.
    The rotary toolchanger sounds great, but this is not going to be a simple thing to build and get working well, whereas gang tooling can be.
    I don't really see it as an issue of production only. I see it as a case where if I am not using the tailstock, I get to have a toolchanger. As I look over what I do in my shop, other than cases where I have the chuck or die holder in the tailstock, I'm not using it very often, so this is a great solution for me. In addition, I've got to undertake machine work anyway to apply a ball screw to the slide, much as Al and Ron111 are doing. Once again, with just a little more work, I get my tool changer.
    I think if you want to use something like this for real production, you'd need to line up a bar feeder or puller and a pneumatic chuck. Also doable, but not my cup of tea at the moment.
    One last advantage is that I believe it will add substantial rigidity and perhaps precision to my little Asian lathe.
    Best,
    BW
    PS The choice of aluminum stems from not wanting the metal to move after machining as steel or CI can. One could certainly have a go with CI. I rather like the way the material machines, and use it for my chuck backplates. If so, I would be tempted to look into having it stress relieved.
    Dec 2004
    524
    Well, I already have a pneumatic collet actuator, although last time I tried it it didn't open real well. I suspect it is an o-ring or seal issue that I'll address when I get a chance.
    A bar puller is a very simple DIY item. A pneumatic bar feeder also seems like it should be a reasonable DIY task. Even with a manual collet, gang tooling should improve productivity tremendously.
    Since most of what I'm machining is brass or aluminum, an aluminum baseplate seems pretty reasonable. It would certainly be easier for me to build with.
    I've written to Omniturn to try to get the dimensions of their Tee slots and tooling plates. It seems reasonable to try to be able to use their tooling. There seems to be multiple vendors that supply compatible tool holders for that system. Unfortunately, Omniturn never replied to my email.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Apr 2006
    5
    Another small gang machine is the GT-27 from SNK. http://www.snkamerica.com/prodigy/prod/27.shtml/
    Kia also makes some very reliable large machines.
    http://www.kia-hyundaimachine.com/TurnList.htm
    Gang tool machines are much faster for small parts than turrent machines. The moves are often much shorter and there is no lost time while waiting for the next tool to rotate into position. There also has to be enough space between tools so that one tool doesn't hit while the active tool does it's job.
    RogerH
    Sep 2006
    6463
    Hi all, In the shop where I used to work in the 90's we had 2 Mazak CNC's and they both had the "gang" tooling method of tool holding.
    We were given them by another subsidiary of the company, and they were considered too long in the tooth for the then present day methods.
    If I remember rightly the whole headstock moved in and out, on it's own slide, and the tools on the crosslide just moved across and back, also no tail stock as all the end work was done from the crosslide.
    What a lot of people fail to realise is that these methods are geared to PRODUCTION machining, and when you come to apply it to general everyday turning and low volume work it doesn't work.
    Take a capstan lathe for example, unless you are getting 200 batch runs, it is not economical to set up and make the parts. It don't pay, and nobody will pay your labour rates at the end of a short part run.
    The same goes for CNC set-ups, if you're just having fun making parts using sophisticated state of the art technology, don't expect to compete with anyone running an old capstan lathe with form tooling and low overheads.
    The point is, if you are seriously making parts to sell, then the set-up and make time will kill you if your act is not up to it.
    There is always someone out there, with time on his (or her) hands, that will make parts for pocket money, and just likes to pick up the low volume jobs that no one else can make pay.
    When it comes to the crosslide versus rotary magazine set-up, then the crosslide will come out tops as it's so much easier to make in the home work shop.
    Provided you can tie the tools down to the crosslide, and space them out to miss each other, then the method of holding them just becomes a number of open sided tool posts with a bolt hole through the middle for a tee nut and hold down bolt.
    The problem of using alluminium for the crosslide is that the tool holders will soon indent the top surface.
    Using alluminium, I would fit a top piece of cast iron or steel with a long tee slot to offset the wear and abrasion.
    There is no reason why any centre lathe could not be adapted to use a long crosslide for gang tooling, (incorporating collets and a bar feeder set-up),just don't expect to use conventional turning methods like supporting long work with a tailstock.
    If your work load is long shaft work then the whole design takes a different turn and the gang method is unusable.
    Many years ago I had a tool that was held in the 4 way tool post, and had a rotary tool magazine that rotated on it, in the vertical plane, with 6 tool slots.
    This allowed 6 different tools to be selected and the magazine was just rotated manually to get the next tool required.
    They have one for the tailstock too, like a capstan lathe, that holds six tools, mostly drills, reamers and taps etc.
    Ian.
    Jan 2006
    93
    Hey Bob,
    Just been reading through this thread...very interesting..how or is it progressing?
    I posted one of the omniturn lathe videos on here a while back, mesmerises me everytime I see it (joy and delight stuff)....ok I need to get out more!
    But, I too want to adapt gang tooling to my next lathe (only a 7x???) but again I only have the need for 3 or 4 tools (including the parting tool and a drill or 2), so can probably get away with just a longer plate on the existing cross slide. The beauty of the 7x is they usually also have a reversible motor so machining from the back is a genuine option (parting etc).
    I only do small production runs in alloy (weekend warrior), but I can see, even for the home shop, how something like this would improve just about every aspect of the job, exact tool settings every time (yes it's a PITA to use shims, but set once and forget), maybe even making up a few complete 'tooling plates' that just bolt in depending on the part required. The only downside for some, as has already been mentioned, would be the loss of the tailstock use, but who's to say you can't leave a gap in the middle of the tool plate with tool posts either side to clear the work. It's all going to be relative to the size of the machine (eg: I'm not going to be rigging up my 7x for a cnc gang tooling production run on a long length of 3.5" diameter alloy!). No point suffering delusions of grandeur.
    Interested to see how yours goes together to possibly adapt to a smaller size.
    Colin
    May 2005
    2502
    Colin, I haven't done much other than consider the design. The basic CNC conversion of the lathe is still not complete. The gang slide will be next, and part of it will be swapping out the ACME screws for ballscrews on both axes.
    Best,
    BW
    Oct 2005
    14
    Any progress to report? My interest in a CNC lathe for hobby work took me down the exact same path re: gang tooling. Most of the effort is already undertaken in CNC'ing the cross slide. I'm surprised this approach isn't more popular.
    Sep 2006
    6463
    Hi all, just read Chola's post #13, about the gang slide being a problem with regards to having a tailstock, but it's not the tailstock that's the problem it's the length of the job if it's supported on a tailstock which prevents the gang slide from being used.
    You can still have a looooong slide with more tools etc, and a tailstock that is used for drilling etc, and gets pulled back out of the way, so allowing the gang slide to work freely, which is a very cheap form of tool turret, but in a linear format.
    If your work entails any form of tailstock support then the gang slide is out.
    Ian.
    May 2005
    2502
    In practice, for a hobbyist, I think it just means that if a tailstock is required to support the work you can only run two tools on the gang slide--one in front and one behind.
    If you wanted to, you could make them both QCTP posts. Any gang slide ought to be set up so you can have one QCTP post at any rate.
    With a CNC you wouldn't use the tailstock for anything but support anyway--no need to use it for drilling, for example.
    Cheers,
    BW
    Sep 2006
    6463
    QCTP, yes that's 1/2 CNC anyway, but a viable solution if you can accurately preset the tooling.
    Now if you can just get a robot arm to change the QCTP holders then the capacity is as good as a tool magazine setup.
    Ian.
  1. Gang 2 controlers ?
    By onthemarc in forum Mach Software (ArtSoft software)
    Last Post: 12-06-2006, 11:31 AM
  2. Setting up a gang bang drill holder
    By joseavina76 in forum MetalWork Discussion
    Last Post: 10-02-2006, 04:28 PM
  3. Gang tool cnc mini?
    By Call Maker in forum Mini Lathe
    Last Post: 03-26-2006, 06:38 PM
  4. gang milling
    By Thoob in forum MetalWork Discussion
    Last Post: 09-05-2005, 02:40 AM
  5. How do I gang axes? X X Y Z not working.
    By Javelin276 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-07-2005, 04:32 AM
