586,423 active members*
2,845 visitors online*
    Nov 2006
    35
    surface finish
    When generating tool path in solids kind of the shape of a half of an egg,is there a way to make the surface smoother in the cam? Now it is chopped up because each segment is about .100 to.150. Ineed them to be about .020
    Nov 2003
    154
    Check your tool path segment length. The longest segment length = xxxxx when you generate the path.
    If you are talking about the simulator that is something different depending upon the settings you choose.
    Set the longest path length to 0.0005 or 0.001 and see how the tool path regenerates.
    mc_n_g
    Jan 2006
    4396
    Quote Originally Posted by fadalman View Post
    Quote Originally Posted by mc_n_g View Post
    mc_n_g
    MC_N_G is correct. As far as the Simulator...... it isn't the best. The Surface finishes you see aren't necessarily what the actual part will look like. Follow MC_N_G's instructions on setting up the Tool Path Step Over and Minimum Line Length. The Simulation should be set to "Fine".
    Cheers!!!!!
    Toby D.
    Schwarzwald
    www.refractotech.com
  1. Surface finish problem
    By gar in forum Haas Mills
    Last Post: 05-22-2008, 03:01 PM
  2. Surface finish
    By skmetal7 in forum Mini Lathe
    Last Post: 09-10-2007, 06:56 PM
  3. Surface finish
    By d.a.v.e in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2006, 08:35 PM
  4. 32 surface finish
    By mroy0404 in forum MetalWork Discussion
    Last Post: 05-29-2006, 03:02 AM
  5. Help with Fly cutter surface finish
    By jderou in forum MetalWork Discussion
    Last Post: 10-14-2005, 05:28 PM
