586,655 active members*
4,077 visitors online*
    Oct 2015
    Low Current output to Laser Tube
    Hello all,
    I have an issue with my Laser machine, I am working with Ben and Nolan from Thunderlaser to solve my issue but thought I would see if anyone else has had a similar issue:
    Mars 90 100W CO2 laser machine
    Problem:
    Does not cut materials as used to, ie used to be able to cut up to 1/2 wood with relative ease. Now will not cut 5.2mm plywood. Using the material settings for 12mm MDF in RDworks I cannot cut 5.2mm plywood. I have replaced the Laser tube, same result. Read the amps to laser tube ~4-5 mA at 60% setting, should be ~28mA. Replaced the Power supply, still the same result. I hope someone has some ideas.
    Feb 2014
    187
    Re: Low Current output to Laser Tube
    Just a thought - have you cleaned and made good the high voltage and low voltage connections on the tube??
    Oct 2015
    Quote Originally Posted by davek0974 View Post
    Dave
    Thanks for input, the laser tube is brand new as well as the power supply, so connections are brand new, factory installed.
    Dec 2020
    Hi.
    Did you find a solution to your previous problem, I mean weak laser power. I have the same problem. Thank you
    Jan 2008
    940
    I have found that on one of my lasers if the min power setting is set below the max setting my laser will only cut at the low setting even if I tell it to cut a 90%
  1. Safe maximum current for 40w c02 laser tube
    By glavey in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-13-2016, 02:27 PM
  2. Did I just clean the AR coating of Wifey's laser tube output window?
    By Byteman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-16-2015, 09:43 AM
  3. problem with PSU wiring for 80W Reci CO2 tube - only getting 4 mA output to tube
    By gbatten in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 01-06-2015, 12:53 AM
  4. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  5. output from new laser tube suddenly weaker !
    By namara in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-05-2014, 08:28 AM
