586,770 active members*
8,984 visitors online*
Results 1 to 9 of 9
    Apr 2007
    327
    VF2 programming
    I have a project I need done and a local non-profit has a VF2 that can do the work, the problem is that they have no clue how to program and they told me their software expired. They have been using another local shop to do programming for anything they need done but the person there left and they don't know how to reach him.
    So, does anyone here do programming? I'm out of my element, I do laser engraving, so I'm pretty clueless as to exactly what needs to be done. I do have a detailed drawing but I don't know where to go from there.
    Thanks for any help!
    May 2011
    308
    Re: VF2 programming
    Quote Originally Posted by LaserImage View Post
    You need a CAM program setup with a post processor that will generate GCODE for your VF2. You can download a free version of Fusion 360 from Autodesk, This program combines the CAD, CAM and post processor into one package and it is free for hobbyist. You probably can load your existing cad files into Fusion with out too much trouble. We did some test runs with Fusion and got it working within an hour or so using the haas post processor from Autodesk. Learning about tooling, work holding, tool offsets, speeds and feeds...thats a lot to take in with some one elses expensive machine. You can do it but I would not expect to be making great parts the next day.
    Apr 2007
    327
    Re: VF2 programming
    That's what I was afraid of... I've used Fusion 360 and it seems easy enough, but like you said, tooling, speeds, feeds, etc., are a bit more complicated than that. Unfortunately, the people who have the machine know even less about it than I do so it looks like I'm probably out of luck. I may try to find another local shop that knows the machine and see if they can give the rest of the info I need after I do the design in Fusion.
    Thanks for your reply!
    Mar 2017
    Re: VF2 programming
    Buy said VF2 and let loose
    or let me buy it, either one haha :cheers:
    Apr 2007
    327
    Re: VF2 programming
    I need it to make a $200 part so buying it isn't likely... lol. The org that has it uses it so little that they may be interested in selling it, you never know!
    Oct 2010
    171
    Re: VF2 programming
    LaserImage,
    Programming (CAM) is only a portion of the work required. As you probably know from your laser work, you will need to set X,Y,Z work offset values. Additionally, tool lengths need to be measured (touched off either on the top of the part, the table, or some reference), and then adjustments made to your total Z offsets depending on how you set up the tools.
    Much of the above goes hand-in-hand with the work done in CAM.
    Fire away if you have question.
    PM
    Feb 2009
    311
    Re: VF2 programming
    I don't understand how an organization can just have a $50k+ machine sitting doing nothing? It boggles the mind!
    Anyway, where are you located? Perhaps there is someone here that is close by and would be willing to help. If you're in the Chicago/Milwaukee area I would be interested.
    C|
    Jun 2004
    6618
    Re: VF2 programming
    It's a non profit organization. They can't run it or they run the risk of making a profit.
    There is also an RFQ here at the zone. Submit your needs there.
    Whoever gets the work will likely want to use their own CAM anyway.
    Lee
    Mar 2007
    113
    Re: VF2 programming
    We have a vf2 haas and can cut your part and ship it to you. Do you gave a 3d model of it and we can quote it
  1. Programming using 3-D
    By AmpOverdrive in forum Alphacam
    Last Post: 04-15-2015, 12:09 AM
  2. Cad Programming
    By Dukie94 in forum Uncategorised CAD Discussion
    Last Post: 03-19-2015, 04:42 AM
  3. Xilog 3 Parametric Programming Offline Programming
    By julioykaly in forum Commercial CNC Wood Routers
    Last Post: 04-27-2013, 09:22 PM
  4. Are you using WCS for programming?
    By Steve Arteman in forum Mastercam
    Last Post: 05-10-2012, 10:56 PM
  5. cnc programming
    By ADELWEIS in forum Employment Opportunity
    Last Post: 06-29-2009, 07:06 PM
