586,655 active members*
3,492 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Tips for Selecting Contours with Lots of Segments
    Jul 2007
    139
    So I'm trying to program a simple 2D contour toolpath and selecting the outline as a continuous chain isn't working properly. I've imported the outlines as a DXF from adobe illustrator, and extruded them to the give me a solid model. Now when I go into CAM and try to select the outline, Fusion only wants to select one line segment at a time, and there are probably hundreds of segments, so I don't want to pick them one by one. The last time I cut letters like this I had problems trying to work directly with the 2D outline, but making a 3D solid model solved that problem. Now I was able to select one complete outline by chance when I moused over one tiny spot and the whole chain selected, but the rest of the letters won't let me do this. I was hoping there would be an option to right click and select all tangent lines or a whole loop, but haven't found that option. Is there something I'm missing here?
    Dec 2013
    5717
    Re: Tips for Selecting Contours with Lots of Segments
    Could you post the dxf you are having a problem with? I have a couple of ideas.
    Jul 2007
    139
    I've attached a screenshot of the issue and a link to the 3D model. The script on the right finally allowed me to select the entire contour after finding one specific point, but the script on the left won't let me select the outside outline beyond clicking each segment.
    Attachment 359432
    A360
    Feb 2009
    311
    Quote Originally Posted by Andrew22 View Post
    Attachment 359432
    A360
    I was able to select the entire chain for "Anniversary" by selecting the long side of the stem first, then clicking it again to switch to closed contour, then mousing around the letters to find one segment that would give it enough of a hint to pick up the whole chain. Then accept the chain and it's good.
    C|
    Jul 2007
    139
    That's great, I just tried that little trick on my outline and it worked. I've only used this method for selecting open chains before, but spent far to long clicking on segments without thinking about trying this for closed chains.
    Feb 2009
    311
    The open/closed chain selection thing is a little funky until you figure it out. Maybe 95% of the time it works great but for really complicated selections it bogs down. Fortunately there is almost always a workaround.
    C|
  1. Looking for help in selecting contours
    By adam_m in forum Mastercam
    Last Post: 12-31-2016, 06:05 PM
  2. Replies: 5
    Last Post: 07-03-2012, 08:21 AM
  3. Selecting Mutliple Contours
    By moldmker in forum BobCad-Cam
    Last Post: 10-18-2007, 11:25 PM
  4. anybody compare HT finecut tips to TD 1Torch tips for dross?
    By Knut in forum Waterjet General Topics
    Last Post: 09-29-2006, 07:17 PM
  5. Drafts: Tips for vendors and tips for RFQ writers...
    By InspirationTool in forum Employment Opportunity
    Last Post: 12-21-2005, 03:44 AM
