586,643 active members*
2,626 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > My DIY power drawbar for the PM940 CNC VS No air needed
    Oct 2006
    205
    Take a look at my DIY power drawbar for the PM 940 CNC VS. I already had a Milwaukee right angle impact tool which I used for the drawbar. I can get quite a few tool changes on a single charge. There are two speeds and I only use the slow speed for now. This is my first prototype for this drawbar. It seems to be working just fine. I like it because it doesn't need an air compressor. It was fast and cheap to make. I can still use the impact tool be loosening up 2 set screws.
    Rod in San Francisco
    <span style="color: rgb(20, 20, 20); font-family: Georgia, &quot;Times New Roman&quot;, Times, serif; font-size: 14.6667px; background-color: rgb(252, 252, 255);">https://youtu.be/U9GQOpZ6fEc
    Aug 2016
    8
    Re: My DIY power drawbar for the PM940 CNC VS No air needed
    Nice stuff! Will consider doing something similar!
    Sep 2017
    32
    Neat. Thanks for sharing.
    Do you use the driver itself to torque the drawbar? Or unnecessary with the battery powered impact performance.
    Dec 2013
    290
    Is the torque applied consistent? When I setup a butteryfly impact gun, I dialed in the valve on the gun to set the torque to around 25ft lbs. I used a torque wrench on the drawbar to verify the torque a few times before I called it good.
    To little, and you might run into tool pull out depending on how hard you run your machine. To much, and you risk breaking the drawbar.
    I have a M12 3/8 ratchet wrench, which I mainly use on my jaw bolts for the vise. I do not feel like it has very much torque, but its rated at 35ft lbs.
    Work: Hurco VMX42/VMX50 - Shopsabre 4896 - Bobcad V4 4axis pro
    Home: RF45 with Ajax CNC Controller - Bobcad V27 3 axis pro
  1. 30Taper YCM30 Drawbar or power drawbar options.
    By countryguy in forum Knee Vertical Mills
    Last Post: 12-28-2014, 06:15 AM
  2. My air over oil power drawbar
    By Etced in forum Tormach Personal CNC Mill
    Last Post: 03-17-2011, 09:00 PM
  3. my power drawbar
    By hanover owing in forum Syil Products
    Last Post: 01-25-2010, 08:16 PM
  4. X2 power drawbar
    By X2cnc in forum Benchtop Machines
    Last Post: 09-20-2008, 01:39 AM
  5. power drawbar
    By fourperf in forum Bridgeport / Hardinge Mills
    Last Post: 03-22-2006, 03:28 AM
