586,538 active members*
2,930 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Prolight 3000 Turning Center
Results 1 to 20 of 26
    Mar 2017
    6
    I just bought a Prolight 3000 lathe turning center from a closing school. Came with everything, ATC, ISA card, control box and everything else. I would like to upgrade it tho because the softwaer is kinda limited and computer is old because of isa card. I looked up a little and doing a Mach3 conversion is apparently the way to go. I am very new at this, only have worked with new CNC never modified any. What would be the parts I need? I know I would need a control board but is that it? What brand is the best for this application and somewhat easy?? Thanks!
    Jul 2005
    163
    Re: Prolight 3000 Turning Center
    I bought a Prolight 3000 last year. It had come from a school, and I got it intact and working, original computer and all. I have used it several times since, and I can just say - use it the way it is. The software does all the normal things, and you don't have to mess around with anything. It's not hard to use, once you are used to the interface. Mine runs under Win95, so yes it's old. However, it works just fine, so I use it as is. Since you are just learning anyway, there is no advantage to updating the controls until they fail on you. Keep in mind that that may happen, but until then - make chips!
    Incidentally - you have a lucky find - mine didn't come with the turret(ATC), nor a tailstock (factory option, never installed). I found a second one, with no driver box or computer, and it doesn't have the ATC or tailstock, either. (The second one is set up for gang-tooling, though).
    Mar 2017
    6
    Quote Originally Posted by DSpeck View Post
    I was going to do that but what's happening is I use Fusion 360 just because I have used it forever and know it well. But it makes the machine plunge and do weird movements but in the simulation In fusion it doesn't? What cad cam program do you use?
    Jul 2005
    163
    I usually hand-write the program. Hand-writing lathe code is a lot easier than mill code. I've used Mastercam at work, for some parts there. There are a few free lathe CAM programs around, for basic 2-axis lathe stuff. Look up Ezilathe, and GrblGru, as a couple of examples. I have several other CNC lathe projects, but they all need modernized controls, so I haven't done a lot with lathe CAM yet.
    The post processors in Fusion 360 are written in javascript and very easy to modify. My CNC lathe uses an AhHa controller that has quite a few unconventional gcodes but I was able to easily make it work.
    I'd be happy to work with you to get a working post for your controller. Here's a thread where a couple of us worked on making a post processor for the Dynamechtronics SKIP controller where the code is far from gcode: http://www.cnczone.com/forums/dyna-m...oftware-2.html
    Let me know.
    Dave
    Mar 2017
    6
    Quote Originally Posted by dammachines View Post
    Let me know.
    Dave
    Hey Dave that would be great! I'm pretty new to this so that would be great. Right now it's a stock controller.
    Sent from my iPhone using Tapatalk Pro
    Quote Originally Posted by 4DCustoms View Post
    Does this look like the manual for your controller? http://www.intelitekdownloads.com/Ma...WIN_Manual.pdf
    What post are you using right now? The generic fanuc? Can you attach a copy of a program you've tried to run unsuccessfully?
    Oh, I think you might want to take a look here before we do anything. https://forums.autodesk.com/t5/hsm-p...ht/true#M10373
    Looks like Autodesk already has a turning post available!
    Dave
    Funny during my search I see that I've already worked with someone on a Prolight 3000 post a while ago. https://forums.autodesk.com/t5/hsm-p...ght/true#M3749
    Mar 2017
    6
    Dave
    That's the thing! I use that post haha and it still doesn't work that's my problem.
    Ha! Well, that answers my post question.
    Do you have a sample program that you've tried to run? We'll figure it out.
    Mar 2017
    6
    Yea just upload the .nc?
    Yeah, the .nc file and some information on what the lathe is doing wrong. Are any of the moves what you expect?
    Jan 2006
    107
    Dave, I stumbled upon your posts here, lucky you!
    I just bought an old CNC Lathe, It's a "Red Cam RLA9200" that came from a school and was used very little, looks new.
    It uses AHHA. I have never run a CNC Lathe but have run CNC router/mill/plasma for years. I have no problem writing Gcode for that. I have no code for the lathe, I tried to write a simple code for the lathe thinking it's just 2 axis and m3m5 to turn on off the spin. I have had very limited results, there is something missing in the code i am trying to use. Is there any chance you could share a simple code that would run your ahha lathe? I expect that if I get the start sequence and see a few code details, I could then edit and write code that would work. I just need to get spindle rotation and a couple short moves on the 2 axis to get started.
    Jan 2006
    107
    Morgan
    Hey Morgan,
    Yeah the Ahha control definitely has some oddities. Let's see if I can remember a few... It is radius mode only. X coordinates are negative if you use a front tool post. Most (if not all) numbers need to have a decimal point in them. G28 doesn't work well on my machine, but that might be just my machine because of something in the MCDMAP.AGC file (contains the macros for things like tool changer, spindle control, etc). I know there are more. My brain is just a little worn out at the end of the week here.. : ) Have you checked out the AHHA yahoo group? There should still be some info there on tool offsets and threading.
    I've attached the code that I believe should be the part on that Youtube video. Should give you a good start! Feel free to PM me here if you have any specific questions - so we don't take this thread off topic for too long.
    Dave
    Jan 2006
    107
    Thanks a million Dave! I ran downstairs and added the decimals, It Works! Thank You!
    Morgan
    Mar 2017
    6
    Hey Dave! Sorry for the late response I was away all week but there are some weird movement, I think around line 34 it plunges for no reason here is the .nc code 'PAWN.nc' | TextUploader.com
    Dec 2019
    Can you tell me where you bought it? I saw it on Christmas Promo code at Reecoupons, and I really found it quite good, Plz let me know about your one, and also show some pics too, It will help me to buy a best one.
    Dec 2020
    Quote Originally Posted by claramax600 View Post
    For christmas sale check here...
    Mar 2022
    Procedures for Basic NC Turning Using a ProLight 3000 Computer Numerically Controlled Lathe
    Built bar coupon
  1. Prolight 3000 CNC Turning Center questions
    By abeship in forum Benchtop Machines
    Last Post: 08-19-2022, 08:31 PM
  2. WTB: ProLight 3000 Turning Center, with tailstock
    By dmalicky in forum Benchtop Machines
    Last Post: 03-12-2015, 06:41 PM
  3. WTB: ProLight 3000 Turning Center
    Last Post: 05-06-2014, 04:23 AM
  4. Prolight 3000 turning center (lathe)
    By closetgenious in forum Maintenance DIY Discussion
    Last Post: 02-07-2014, 06:05 PM
  5. Prolight 3000 turning center C-axis driver failure
    By Robert440 in forum CNC Machine Related Electronics
    Last Post: 09-10-2011, 03:05 AM
