586,560 active members*
3,943 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Problem making paths in Freemill (Visual Mill)
    Dec 2016
    134
    Hello.
    I'm trying to make g-code using Freemill on a step-file.
    I've made the step-file in FreeCAD.
    Step 1: I load the file into Freemill.
    Step 2: Z is upwards so the coordinate system is ok.
    Step 3: I'm not interested in the boundaries at this time, only the pocket in the middle so I set 0 offset.
    Step 4: The pocket is 20mm deep so a 30mm flute tool should be ok?
    Step 5: I guess the speeds really don't matter at this point as this is just to generate the path.
    Step 6: Toolpath display. Stepover is 1mm in horizontal direction, but in Z direction it takes all in one cut. How can I change this?
    Step 7: I can't see anything useful here, can you?
    Step 8: Loaded the output file into UCCNC to see how it turned out.
    Is it possible to make this work in Freemill?
    If not, are there some free CAM programs that can do things like this?
    Attached Files Attached Files
    Apr 2016
    16
    Re: Problem making paths in Freemill (Visual Mill)
    Hy Buoyen,
    Not free, but I would recomend you check out CamBam.
    I use Geomagic (Alibre) and ViualCam Professional for Geomagic, but I have a licenced copy of CamBam, that I still use now and then.
    Nick.
    It's been a few years since I've used Freemill, but it doesn't do multiple passes. It's a limitation due to it being free.
    Jan 2004
    3154
    You could very easily edit the gcode to turn the profile moves into a sub-routine with the main body being the machine setup codes and your Z moves
    www.integratedmechanical.ca
  1. Visual Cam 1.0/visual mill 6.0 5 axis?
    By Swets in forum Visual Mill
    Last Post: 03-05-2017, 10:32 PM
  2. Visual Mill 6.0
    By ibrich in forum Visual Mill
    Last Post: 08-14-2014, 09:48 PM
  3. Visual mill accuracy problem
    By JackWilliam in forum Uncategorised CAM Discussion
    Last Post: 04-25-2013, 07:54 PM
  4. Problem with 3d paths for cutting
    By vinot in forum Composites, Exotic Metals etc
    Last Post: 12-01-2008, 04:44 AM
  5. Visual mill
    By merritt boyd in forum Mach Software (ArtSoft software)
    Last Post: 06-30-2007, 11:24 PM
