586,584 active members*
2,978 visitors online*
Results 1 to 13 of 13
    Mar 2017
    5
    Bridgeport Romi EZ-Path Boot Disk
    I have a Bridgeport Romi EZ-Path Lathe Circa-1993. Replaced the battery, but control needs to have DOS boot disk. I have the backup software, but no Boot. Can anyone help?
    Jun 2007
    129
    Re: Bridgeport Romi EZ-Path Boot Disk
    You may have a bad floppy drive.
    Mar 2017
    5
    Quote Originally Posted by reabdet21 View Post
    I have an extra, I will try that. Thanks.
    Dec 2013
    28
    Any old dos 6 boot disk will get you in. Then you will have to install dos on the HDD and your other software for th e machine.
    I have all of it if you need it.
    Steve
    Mar 2017
    5
    Quote Originally Posted by Machinehead57 View Post
    Steve
    Thanks Steve, I will have some time to work on it tomorrow. I have the EZ-Path Machine software, but I'm not sure I have a copy of DOS anymore. What version of DOS do I need to install. I have a DOS 3.3 boot disc. will that work to get me in? I appreciate your help! This machine is old, but it only has about 50 operating hours. It was just left without power for too long. Hopefully with your help I can bring her back to life. Thanks Again.
    Kasey
    Dec 2013
    28
    Honestly I don't know if the EZ path will run under dos3.3. Mine uses dos 6.6. Do you know how to make the computer boot from the A drive? If so try the dos 3.3 it won't hurt. The computer itself will boot and run the older dos just don't know if the EZ path will. Dos is a basic operating system that runs a computer. Windows is actually a graphical program to run dos commands with graphical icons. The Ezpath software will run under windows but there is no windows software (driver) to run the interface card for it.
    Steve
    Mar 2017
    5
    Steve
    Thanks Steve,
    I can pick up a copy today from a friend. Again, your help is greatly appreciated. I will keep you posted.
    Kasey.
    Mar 2017
    5
    Quote Originally Posted by Kasey View Post
    Thanks Steve,
    Kasey.
    Steve,
    I tried a DOS 6.22. Machine booted, but when I tried to load EZPATH-ROMI software it told me I was using the incorrect version of DOS.You noted that your machine runs on DOS 6.6. I haven't been able to find a down loadable 6.6 version. My machine states that the processer is from 1994 and is a 386. What type of processor is your machine?
    Kasey
    Dec 2013
    28
    Steve,
    Kasey
    Mine is a 96 with the 386 processor. The dos 6.6 was a typo I run dos 6.22. The version of the EZ path will determine what dos you need. You probably need DOS 3.1. I think I have a copy of it if you need it. My EZ path version is 250-21-687. Whats yours?
    Jul 2013
    16
    Hi guys, would you mind sending me a copy of the software please? I have an EZ Path S
    Steve
    Dec 2018
    Any one have a copy of the ez path software. We can't find our install disc's.. help..
    Dec 2018
    Jul 2010
    7
    i need the ez-path II software... can you help me??
  1. bport/romi ez-path won't boot up
    By MIKE JEFFERS in forum Bridgeport / Hardinge Mills
    Last Post: 04-14-2015, 06:16 AM
  2. EZ path boot disk
    By flashpointusa in forum Bridgeport / Romi Lathes
    Last Post: 11-01-2014, 02:12 AM
  3. ez path boot disk
    By sempe0 in forum FeatureCAM CAD/CAM
    Last Post: 03-15-2010, 04:32 PM
  4. bridgeport ez path lathe boot disk
    By sempe0 in forum Want To Buy...Need help!
    Last Post: 03-11-2010, 06:10 PM
  5. EZ-PATH I boot disk missing...
    By Jonne in forum Bridgeport / Hardinge Mills
    Last Post: 09-29-2009, 03:54 PM
