So I am tooling up my lathe and I have need for smaller diameter internal grooving tool. How do you guys install these smaller diameter tool into the turret? Machine custom sleeve with set screws? Buy sleeves?
I have a bunch of ER16, ER20, ER25 and ER32 with 3/4 shank, so I just use the right collet for the boring bar and put the 3/4 shank in the boring bar holder of the turret.
Jeff
I use these on my turning center. MSC carries them.
North Americas Leading Manufacturer of Bushings, CNC Lathe Tool Holder Bushings for CNC Lathes including : Bushings, Set-up Tooling, Toolholder Bushings, Z Bushings, C Bushings, J Bushings, B Split Bushings, DD Bushings, L Bushings, LB Bushings, LBF B
